soon to be first time tractor owner
   / soon to be first time tractor owner #11
I really can't improve on the information/advice given by others. As Buppies noted, just do a close inspection on fluid levels, clarity of hydro fluid, proper levels, operation/functions etc., you shouldn't be able to hurt that tractor in 30 hours unless you submerged it or ran it into things and all this would be obvious.
The GL can be a bit notchy when changing between ranges, so don't worry about that, just slightly press on the HST pedal and it will shift, same goes with MFWD engagement, sometimes smooth as butter and sometimes a bit reluctant, turn front wheels left to right, roll a bit or lift front wheels with FEL and it will release the binding as the front wheels have a bit of lead.
It will smoke a bit on start-up and rattle then settle down, just the interim Tier IV, my L5030 didn't smoke as much.
I was initially unimpressed with the HST+ and had to get use to it to fully appreciate it, best feature for me was the dual range.
Kubota HST-Plus Transmission - YouTube
Yes, at least in my experience, tractors shrink during use on your own property. My wife, you read right, my wife told me to get a L5030HSTC when I was looking at 32-35HP models; says me, "Oh that's too big"; "Oh, you'll like it once you use it" says her and no I have not heard the last of it.:laughing::eek:
As to size, maybe, maybe not, but as mentioned you can use it practically free if it is too small. I doubt I can do much if anything beyond turning a little bigger cutter or tiller with my 5740 than you can with a 3940, it just may take a little longer.
Tasks are sometimes more important than acreage, so it's hard to really set guidelines.
If after reading this you have mental picture of us standing around chewing on a grass stem, scratching our heads and kicking the dirt, you might be spot on, this definitely ain't an exact science.:laughing:
   / soon to be first time tractor owner #12
The hydro and hydraulic filters would not be ready to change yet for another 20 hours. The tractor is essentially new. As long as there is not something wrong with it, just check it out thoroughly and decide. You can tell if the filters are original if they are gray painted the same as the lower chassis. If they are white then they have been changed. But I would see no reason why they should have been changed at 30 hours. If you like the tractor, and you can save a wad of money, I can't see why you would not want to buy it.
James K0UA
I pulled the trigger on the L3940 after going down to check it out. It is every bit as good as the pictures indicated, it was only used to bail hay, the bucket is not even scratched as he only used it to lift hay bales. The machine ran perfectly, everything checked out and it looks like I essentially bought a new tractor for about $7000 less than my best new L3940 quote from a dealer. It still has warranty until June of next year. I am happy with my decision to buy.
I thank everyone for their input, suggestions and sharing their experience with me.
Now onto the attachments!!
   / soon to be first time tractor owner #14
Congratulations on your new tractor, maybe post some more pictures when you feel like it. I think you will really enjoy it.
James K0UA
   / soon to be first time tractor owner #15
Congrats!
   / soon to be first time tractor owner #16
What happened to Kubota resale? A 1 year old 30 hour machine loses 7,000$?
   / soon to be first time tractor owner #17
Trouble maker. :laughing:
   / soon to be first time tractor owner #18
   / soon to be first time tractor owner #19
Better than jd??!! :shocked:
   / soon to be first time tractor owner #20
Got me.:confused:
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
RV Hitch (A50121)
RV Hitch (A50121)
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
