lift arms raise on their own
   / lift arms raise on their own #1
coolconnection
Gold Member
Ohio
Massey Ferguson GC1723
Anyone have this problem? I disconnect/unhook my mower deck. Turn the tractor back on with nothing on the quick attach and the lift lever in neutral position the lift arms start to slowly rise up on their own. I checked several times by moving the lever but it still rises on its own. If you had it what did you do to correct it? Thanks
   / lift arms raise on their own #2
Sounds like your valve is not return back to neutral.
Check springs and nut in the can on the bottom of the valve.
   / lift arms raise on their own #3
Is your draft control still on? Mine will do that if the draft control is still on.
   / lift arms raise on their own #4
The 400 series doesn't have draft control.
I had that happen once after a very long day of work. It bothered me. I moved the joystick around quite a bit in all directions. It never happened again.
I'd call Terry at Power Trac and see what they say.
Thanks I will try moving the joy stick around more the next time I am on it. I did check the hydraulic valve under the lever and it was very lose. I left it lose and it didn't help so I tightened it.
   / lift arms raise on their own #6
Just so we're clear, when you say you left the lift lever in the neutral position, you meant the float position, correct?
If so, that's the same thing I experienced. With no weight on the FEL after I removed the attachment, the FEL arms would raise while in the float position. Not fast, but up they went.
No not float. Neutral between up and down.
   / lift arms raise on their own #8
I sprayed some dry silicon lub in the bottom of the lever while moving it around, kind of like MR did, and that seemed to loosen things up so that it wouldn't stick.
   / lift arms raise on their own #9
Oh. Well, that's different than what I had. Mine occurred in float with no implement on it.
Perhaps there is some crud in your valve causing it to not close completely and leak fluid to the UP side of the lift cylinders.
Try cycling the heck out of it by moving the joystick rapidly between up and down to knock the crud loose.
If that doesn't do it, you may need to remove the valve (not a fun job) and clean it out or have it serviced at a local hydraulic shop if you can't do it yourself.
   / lift arms raise on their own #10
Did you talk to Terry about this?
I had trouble with leak down caused by a pilot sticking on my joystick. Leakup may be caused by crud in the particular valve, but you may want to try the following, before taking the whole valve assembly off the tractor to a hydraulic shop. The procedure is pretty straightforward.
First make sure the arms are on something solid, like the ground. You do not want them coming down on you. When you open the valve assembly, it will release any remaining pressure, so you want to ensure that all the cylinders have been relieved before starting the process. (PT engine off, cycle the joystick amongst all the positions long enough to release any pressure.)
On the valve assembly of the joystick, there is a small cap on the valve that covers a check valve. If you unscrew it, you may dislodge the crud. I had an issue on my 1445 that was solved by doing this. I never saw the crud, but disassembly, cleaning and reassembly caused the issue to go away. Just get it really clean before you start the disassembly, and keep it clean during the process.
All the best,
Peter
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
Fire Place Mantel (A49462)
Fire Place Mantel...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
