Questions about my belly mower on 4100, maybe customize it?
   / Questions about my belly mower on 4100, maybe customize it? #1
mikenmichele
J/D 4100
Hi guys. when using my 60" belly mower I cant use my rear 3pt as they both go up and down at the same time. I thought I heard of a kit to pin the belly mower up when I want to use the rear 3pt? The other thing Im considering is converting my belly to rear mount. Has anyone done this? Any pics to share? thanks!!
   / Questions about my belly mower on 4100, maybe customize it? #2
It's called a 'latch kit' I believe. It is basically just two brackets that bolt to the frame, and two turnbuckles attached to a short length of chain. It keeps the brackets that ride on top of the 3ph in the up position.
Converting it to a rear mount would involve a lot of fab work as well as changing the rpm and possibly rotation of the pto.
   / Questions about my belly mower on 4100, maybe customize it? #3
I would get the hydraulic lift kit, then it just uses the rear hyd. remotes for the deck and keeps the 3 point independent.
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
New/Unused 7ft Stainless Steel Workbench (A51573)
New/Unused 7ft...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
Case Maxxum 140 (A50120)
Case Maxxum 140...
