water in tires
   / water in tires #1
yellowfox
paradise tx
massey ferguson 451
I have antifreeze in my back tires. does it still need air in them.
   / water in tires #2
Yes, you should leave 15% of volume or air.
   / water in tires
ok the air pressure should be 35 psi that shows on the tire. so how much air should I put in the tire. thanks.
   / water in tires #4
You need to check the air pressure with a gauge, just as you would if the tire did not have water in it. The best way to do that is to have the valve stem at the top (12 o'clock position), and preferably using a gauge that's made for both air and liquid (they don't cost much, if any, more than an air only air gauge). Since I usually checked my tire pressure in the shop where the air-compressor was handy, I'd give the tire a quick shot of air to clear the valve stem of liquid before using the tire gauge.
   / water in tires #5
   / water in tires #6
When we used a tractor with water/liquid in the tires, we put the valve stem at 10 o'clock or 2 o'clock and filled the tires until water was present but not pushing itself out. Then, rotate the tire to 12 o'clock to put the air in and fill to recommended tire pressure on the tire.
   / water in tires #7
Filling tires has a material effect on traction. The weight helps, but the liquid in the tire will not allow it to flex as much and the tire may not have as much ground contact, and the ride will be harsher. The more air in the tires, the better for flexing and ride. Since I am more concerned about adding weight to my CUT, I have it filled to about the top of the upper rim. That allows enough air so it isn't unbearable. You have to have some air, but opinions vary on exactly how much is optimal. Mine works for me. You can research and get all kinds of info online.
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
TANK MANIFOLD (A55745)
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
