Did a bit of plowing yesterday
   / Did a bit of plowing yesterday #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Me, the L5740 and the Oliver 3 bottom rollover. In a couple of my previous posts about plowing around here, I've referenced the fact that our "sandy loam" soil bears a striking resemblance to concrete if it doesn't have a bit of moisture in it. Yesterday was a good illustration of that point.
The ground was a black eyed pea patch that was hard, hard, hard, HARD! Did I mention the ground was hard. The poor little 5740 grunted and strained, she could only manage about 3 mph in low range high, but she made it through. It was about 2 acres and it was DRY. I was pulling up dirt clods the size of 5 gallon buckets. At one point, my speed went up and I thought I had hit a soft spot but when I looked back, all three bottoms had come out of the ground and were just sliding on the hardpan. DANGIT! Oh well, I backed up and tried again and got her in the ground.
After it was all said and done it looked ok, not ideal but ok and if we ever get a bit of rain a good disking will put the ground in fine shape.
One thing about that hard dry ground, it sure shines up the moldboards quick.
ps, in reasonable ground, ie with a bit of moisture, I can pull this plow at about 4.5 mph in midrange low and sometimes even midrange high. This afternoon I have another spot near this one to plow that has had water on it. I'll report back on how that goes.
Anyway, though someone might like to hear about this.
ps again, I added my one and only plowing video to my signature.
   / Did a bit of plowing yesterday #2
Plowing cement? Yuck! My biggest problem is excess moisture. But that's what happens when the farm is surrounded on three sides by swamp. I plow at about 3 mph, but I also have much more limited gear ratios to choose from than these modern tractors have. (6 speed tranny, but 2 of them are road gears.) Can't wait to hear how your next field goes with the added moisture.
BTW, nice video!
Joe
   / Did a bit of plowing yesterday #3
. . . One thing about that hard dry ground, it sure shines up the moldboards quick. . . .
I grew up on a farm in SW Oklahoma, and we had all kinds of soil from sand to sticky red clay. Dry sandy ground will indeed shine up a moldboard or chisel sweeps.
   / Did a bit of plowing yesterday #4
Very interesting. Do you have any better photos?
   / Did a bit of plowing yesterday #6
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
