Thanks for all the replies guys.
I had checked out your trailer Paul and noticed the modifications you have made but I saw it on YouTube and did not have an account so could not comment.  The first dump I had came with the ramps mounted on the sides but I much prefer the under floor storage I have with my current Moritz.  It is much nicer to just slide the ramps out and hook them on the rear edge then it is to carry them from the side to the back.  Your aluminum ramps may not be a problem but I have already put a bow in the C-channel ramps that came with my Moritz due to the weight of the
L45 so I had a new pair made with box tubing and they are still straight but they are heavy to lift.
My first dumper was gravity down which worked fine most of the time but there were a couple of occasions where it got hung up (due to lack of greasing on my part probably) but I like the power down feature as well.  I have had a couple of situations where I was dumping over a steep slope and the trailer box was almost vertical when dumped so gravity would be very slow.  Having had both, I prefer the power down.
I have been looking at the Load Trail trailers as I am thinking I am going to go to a tri-axle trailer.  My current 7 ton dumper weighs about 4600 pounds with the pressure treated lumber I have lining the bottom, front and sides of the box and my additonal toolbox on the front to hold all my tie down chains, straps and load binders.  Now that I have the Laurin cab on the
L45 and the foam in all four tires by the time I load the trailer with the
L45, my three hoe buckets, 4-in-1 bucket and my hydraulic forks I wind up being almost 1000 pounds overweight on the trailer and about 800 pounds over on the back axle of my F350.  There are a few manufacturers who offer 8,000 pound axles which could solve my problem but I'm thinking if I am going to upgrade I might as well get the maximum cargo capacity possible hence my interest in a tri-axle.
A company called B-Wise Trailers (bwisetrailers.com) has a really cool video of a two way hydraulically operated ramp/dump gate on their trailers but they don't offer a tri-axle or 8,000 pound axles.  Load Trail released a video in Sept. showing a rear hydraulic ramp/dump gate that looks very similar to B-Wise and if I can get a tri-axle deckover with the hydraulic ramp/dump gate I think I will go that route.
Load Trail offers the telescoping dump cylinder as an option and all large dump trucks use that cylinder type but unless there is a compelling reason to switch I think I will stick with the scissor lift.  The one downside I see to the scissor lift is that there are a lot more grease fittings to keep lubricated on the scissor mechanism versus the telescoping cylinder.
Have a great Canadian Thanksgiving and or weekend for you Americans.
Regards,
Lauren
