Rockshaft Pin Removal -- 4410
   / Rockshaft Pin Removal -- 4410 #1
jeffinsgf
Springfield, MO
JD 4410
I've done some damage to the pins in my rockshaft. I took the nut off the inside, but it doesn't seem to want to budge. It appears to be threaded into the rockshaft, but I couldn't get it to budge, even with a reasonably big cheater bar.
Is it threaded into the rockshaft or is it a press fit?
Any help on getting them out?
Well, here I am answering my own thread...
The pins are tapered. Theoretically a couple good smacks with a hammer should pop it out. Have the replacement pin in hand now, I'll let ya'll know how it goes tomorrow.
   / Rockshaft Pin Removal -- 4410 #3
Not really sure what part you are talking about.
   / Rockshaft Pin Removal -- 4410 #4
I believe he is referring to pin #20. They are tapered and once the nuts are removed, a good whack with a 3 lb hammer should pop them out.
That it did. Easy peasy.
   / Rockshaft Pin Removal -- 4410 #6
I was thinking off of shaft 14. Picture is worth 1000 words. Glad you got it fixed!!
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Grading Bucket Mini Excavator Attachment (A56857)
Grading Bucket...
PALLET OF MIXED IRON, ROUND STOCK, FLAT SQ TUBING (A52708)
PALLET OF MIXED...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
