Snow Equipment Owning/Operating designing a mechanical means to turn a snow blower chute
   / designing a mechanical means to turn a snow blower chute #1
tommyboy1
Member
north branch, michigan
ford 4600
hello all,
I am trying to modify a three point rear mounted snowblower so that i can use hydraulic or electric power to rotate the chute instead of moving it manually. Does anyone have pictures of this type of mechanism on on a commercially built snow blower or have ideas about something they may have created themselves.
   / designing a mechanical means to turn a snow blower chute #2
Here's my homemade hydraulic setup. I used a cylinder that I had laying around doing nothing. Works great!
   / designing a mechanical means to turn a snow blower chute #4
The left picture is one I made - the cable rides on a curved piece very close to the chute. The cable wraps around the chute with the ends tied off. Same idea as Farm King (Allied, Buhler) - right 2 pics. Cable length stays constant through the travel.
Thanks for the info. As someone who has done a lot of metalworking, you did a really nice job! good pictures also.
thanks for all the good info. I finally know where to go now for this type of stuff. thanks again!
   / designing a mechanical means to turn a snow blower chute #7
I used a cheap HF winch. Rope was only used for testing.
   / designing a mechanical means to turn a snow blower chute #8
ZIK
I see a large caster under your blower. Are there 2?
Interested to know how it (they) serve (s).
And nice winch install. All the torque U need as well as correct speed.(I also used winch)
   / designing a mechanical means to turn a snow blower chute #9
Yes there are two swivel casters bolted on (temp setup) to keep the blower from digging into my gravel driveway. So far it's works pretty well except we haven't had enough snow in the past 2 winters to really test it out much.
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2008 D&P WELDING  18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
