Teflon tape for grease gun?
   / Teflon tape for grease gun? #1
paulharvey
Hawthorne, FL
Kubota L285
I blew apart the grease hose on my new to me(ancient, from scrap pile) grease gun. I picked up a cheap replacement hose at HF. Should I use Teflon tape? Old one didn't.
Also grabbed new 1/4" quick connect for air hose, old one was on with no tape, just a thread sealant, probably should tape right.
I've heard of using electric tape instead, and have done so in a pinch, but didn't care for the sticky mess when I changed fitting later.
Only asking cause my 7 yr old son seams to have stolen/misplaced my Teflon tape.
I worked as a plumbers helper many years ago, and did a galvanized steel shop air system at a bus barn, I seem to remember using tape and dope on each connection.
   / Teflon tape for grease gun? #2
I use Teflon tape on fittings all the time, you just have to put it on correctly and not leave any of the tape over the end of the fitting. For a grease gun, you could pretty well do without anything on it and it will seal. I have to remove the fitting from my pneumatic gun to expose the check valve every time I put in a new cartridge to get it to pump out the air and I just screw it back together without any thread sealant and it doesn't leak.
   / Teflon tape for grease gun? #3
i agree.. it's a taper thread issue and will likely seal without it. in doubt.. use dope or a lil tape wrapped correctly.
this is a for sure non critical application that if done wrong.. can be corrected with no loss that a paper towel won't correct.
True, guess I was just trying to avoid stopping at Advanced Auto on way home tonight.
   / Teflon tape for grease gun? #5
any pipe dope just about would work ( not glue ). caulk would too probably.. so would chewing gum. all you are doiung is making up minute space between thread root and point in a taper fitting that deforms pretty good anyway .. plus you are pushing grease not oil aor air.. so leaks are less likely anyway.
gasket sealent.. permatex.. rtv. any of that stuff will work if it will save you a trip.. etc..
Will probably use RTV. After all I dont plan to remove it any time soon.
   / Teflon tape for grease gun? #7
the rtv will come off easy anyway when you do remove it.
UNUSED LANDHONOR 4.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
