Why does it cost so much to repair a tractor?
   / Why does it cost so much to repair a tractor? #21
Despite the high cost of living, it remains popular!:thumbsup:
   / Why does it cost so much to repair a tractor? #22
Brian
I'm curious what type of company you work for or type of equipment you repair that requires $150,000 + worth of tools & equip. and that doesn't even include a truck???? Thanks,Jim
He is a full service mobile equipment mechanic. Here is his shop (from the outside):
Aaron Z
   / Why does it cost so much to repair a tractor? #23
It's called runaway inflation. You think it's bad now, wait another couple of years until the just before the end of Obama's term. I have a sneaking suspicion we're going to find out what it felt like in pre-WWII Germany, and not so long ago in Argentina. Hyperinflation is a pension and savings killer.
   / Why does it cost so much to repair a tractor? #24
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=341842"/>
Aaron Z
I know where that picture was taken but don't remember taking it.
The cost of tools adds up fast. Then figure solvent tank, drill press, 12-ton press, hydraulic hose fitting press, welder, generator, air compressor. Now fill it with nuts, bolts, hose ends, fittings, miscellaneous other hardware, chemicals, etc. It gets to $150k without trying very hard.
Brian
   / Why does it cost so much to repair a tractor? #25
Too true - in most trades, you can scare/scar your bank balance pretty badly just buying a few bags full of quality fittings.
Rgds, D.
   / Why does it cost so much to repair a tractor? #26
And who do you suppose will be getting all the blame laid on them?..."what goes around comes around"
   / Why does it cost so much to repair a tractor? #27
With the liberal media calling the shots, it would be Bush for sure. Ken Sweet
   / Why does it cost so much to repair a tractor? #28
I'd be WAY surprised if your figure wasn't low, and you had quite abit more in a mobile shop like that.
Brian
   / Why does it cost so much to repair a tractor? #29
That is a bit hefty but you pay for the convenience of not taking the tire in for repair. If you feel uncomfortable taking off a large wheel and
tire, or have a injury that precludes you from doing such a job, than by all means have it done by a professional.
In my area, if you bring in the tire and wheel, they charge by the "inch", that is, if you have a 28" rim you will pay $28.00 plus the cost of the patch and or tube, to patch a tube is around $3.50 . But I still think $275.00 is a lot of money especially living only 2 miles from the shop.
NOTE: $1.00.00 per inch/ rim is for a dry tire. Loaded are $2.50 a inch
   / Why does it cost so much to repair a tractor? #30
You may be right. I should really sit down and do a serious inventory. Especially on the replacement cost of my tools. My Snap-On man says I easily have a $100k invested. It's easy to lose the concept of what it's all worth when it's been bought over 25+ years. I was buying shop tools when I worked for dealers knowing I'd be out on my own someday. There's things like $10k worth of toolbox, almost another $10k in a scanner, then you start adding up the value in each drawer. There's probably $2000 worth of PitPal oil and aerosol racks. When you start adding up the Fastenal racks and fastener inventory I bet $10k isn't an unlikely estimate either. Then another close to $10k in the Weatherhead machine, cabinet, hose ends, and fittings, and don't forget hose. I think I'm going to sit down now, lol.
I really had to start tracking my miscellaneous expenses like brake cleaner, solvent, rags, hand cleaner, grease etc. I found I was only recovering a quarter of my costs.I've gotten better but I'm still only up to half. I used to not charge mileage on short trips either, it seemed petty until I started adding it up. $16-20 a tag adds up pretty quickly so does fuel when you consider I spend $60-80 a day on fuel.
Brian
PALLET MISC POWER TOOLS (A53843)
PALLET MISC POWER...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
