Point Gap for a 1974 212 lawn tractor
   / Point Gap for a 1974 212 lawn tractor #1
mputz
Cameron
212 garden tractor
Can anyone point me to the tune-up specs for a 1974 lawn tractor. A manual for changing the points would be very helpful.
Thanks
   / Point Gap for a 1974 212 lawn tractor #2
Kohler engine about 12 HP .020" for points .... look for S and T marks ... go to kohler website for replacement procedure ....
   / Point Gap for a 1974 212 lawn tractor #3
Think it was Kohler engine on my Gravely. It was 0.020".
Ralph
What is an S and T mark?
   / Point Gap for a 1974 212 lawn tractor #5
The S stands for spark, and the T is for TDC. Actually the starting gap on the points is .020 the gap can vary between .016-.024 to actually get the S mark to line up with the exact moment the point open. Best done with a timing light.
   / Point Gap for a 1974 212 lawn tractor #6
If it is a Kohler motor you can go on their website and they have a lot of the manuals on line for download.
Good luck
   / Point Gap for a 1974 212 lawn tractor #7
set at .018 I have set most of the ones I work on at that and run just fine, are the points new or the old ones you are setting?
   / Point Gap for a 1974 212 lawn tractor #8
Even though the spec on the point gap on the Kohler engine on the Gravely, I recall that I had to set it closer (about 0.016") to get the points to close. Determined this with a light to tell when juice was on or off. With a bigger gap, the juice never got turned on to charge the condenser.
On any "pointed" system, try to find an electronic substitute. I had to do this on an Alfa 1300 cc engine. It kept burning the points up because they didn't align properly. I finally put a Hall electronic system on it.
Ralph
   / Point Gap for a 1974 212 lawn tractor #9
We use the 10-20-30 rule. 10 air gap for flywheel, 20 for point gap and 30 for spark plug. And most match packs were .019 to .020 if you could not find anything else.
Kubota KX080-3 Midi Excavator (A50322)
Kubota KX080-3...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
2008 Volkswagon Touareg (A50515)
2008 Volkswagon...
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
