I finally pulled the trigger!
   / I finally pulled the trigger!
I like the easy clip the vermeer has..
This will also be my first disc mower but I hear that really is a nice feature. Heck most things will be my first lol. Looks like I'll be doing my own hay next year. :)
   / I finally pulled the trigger! #42
You will like the Disc cutter if your use to a sickle bar. What baler are you going to be using? Only mistake I made was on my rake Vermeer WR22,going to look into getting new one next year.
   / I finally pulled the trigger! #43
you would be smart to put that 3pt cutter on a caddy.because if you dont have 3 tractors to keep the baling equipment hooked up.its going tobe a pain to hook an unhook the mower.
Can you link me to what you are talking about? I'm still learning, sorry.
   / I finally pulled the trigger! #45
Thank you, I understand now. I'm learning as I go, so I'm sure I'll make some mistakes. Are you all not fans of 3pt disc mowers?
   / I finally pulled the trigger! #47
The only thing I don't like is hooking them up. Mine I about got it figured out,I put a block&2x4 under the skid closest to the 3pt and it levels the 3pt better. Sometimes can get no problem,other times neighbors can hear me cursing it. The caddy also makes cutting your corners easier.
But you don't use a caddy?
   / I finally pulled the trigger! #49
I had 8grand left last year in farm money but put it on wifes new dodge,will be looking for a used one next year. Here is a picture of my cutter to get an idea how unlevel it sets. And the one side that's the lowest my 3pt won't evn go that low.
2021 INTERNATIONAL LT625 (A52472)
2021 INTERNATIONAL...
Kubota ZG327 (A50120)
2011 FREIGHTLINER CASCADIA (A52472)
2011 FREIGHTLINER...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
