3PH Carry All
   / 3PH Carry All #1
motocephalic
Maine
2013 Kubota L3200DT /FEL
Wondering how many have used a rugged carry all and have a model in mind that is a plug and play unit. I am still looking for a nice unit about 60" wide and 48" long with maybe 3' removable sides. I might have to build my own, but I see a market for one especially for a small firewood wagon.
   / 3PH Carry All #2
I recommend a set of pallet forks for 3 point intead of a Carry all. The forks will be more versatile. You can build a custom pallet to your specs and it back into it when you need it.
   / 3PH Carry All
I like the pallet idea, but without sides it would not last 30 seconds. I am running the rig in some new land that has not been managed in 30 years.
   / 3PH Carry All #4
Probably a good suggestion, although more expensive. I bought a used setup like the OP described, removable sides and all. It wasn't very strong and the frame bent when I had a load of rocks on it.
I like the idea of using forks and pallets. I do that for firewood but with front mounted (FEL) forks.
   / 3PH Carry All
TSC has a carry all frame rated at 1000 pounds, that might be my choice, but was hoping for one already made to put to use.
   / 3PH Carry All #6
I use the tsc one and have built a removable wooden deck for it with sides. Its a great firewood carrier. It would likely bend with really heavy materials, but since its loaded by hand that is less of an issue. Other uses include moving lawn furniture (tables, chairs, etc), trash barrels, logs, trees for transplanting and tools and a generator at a job site. Off the tractor and on a dolly i also use mine as a cart in the garage.
The frame consists of a few 2x4s then posts on the side with strapping for a cross brace. The carry all has pre drilled holes so you can use bolts to secure it in place, but keep it remocable.
   / 3PH Carry All #8
I built the one described and constructed on this video. It has been great and the only thing I need to add is large caster wheels so I can roll it around in my barn.
Wilson Outdoors Ultimate Carryall - Part 1 - YouTube
Instead of casters, which would pick up debris if used outdoors, you might look into one of those Harbor Freight dollies. They are cheap and should work in a shop with a concrete floor.
I have a set of 3PH forks and like them for the strength.
   / 3PH Carry All #9
I have one of the TSC 1000# carryalls that I have built into a multipurpose carry platform similar to the Wilson's one. Mine has hinged sides that can be folded in to make a simple L-shaped platform, or folded out to make U-shaped box, or I can slide tailgate boards into channel iron in the sides to close up the back. Finally, one of the tailgate boards can be placed (in brackets) across the sides to make a (fairly uncomfortable!) seat. It is set up with plastic tubes for tool handles (rake, shovel, broom or whatever) and a chainsaw scabbard.
I like the setup I've made, but I would wish for a sturdier frame. Mine bent at the welds from (wet) firewood weight, and I had to have some extra welding done to beef up the weld points. For my DK45, I'd like at least 1500#, if not 2000# capacity.
Bob
   / 3PH Carry All
2019 Freightliner M2 106 26FT Box Truck (A51692)
2019 Freightliner...
MCDON D60 HARVEST HEADER (A51247)
MCDON D60 HARVEST...
2023 JOHN DEERE 333G LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2013 PETERBILT 388 T/A DUMP TRUCK (A51247)
2013 PETERBILT 388...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
