new guy with a 5055E
   / new guy with a 5055E
thanks gentlemen. and yes tractors are great i can see my problem becoming when can i use it next how can i make it do x, y, or z so i don't have to
   / new guy with a 5055E #12
That is not a problem, That is the fun part. The problem is that some of those solutions require an attachment that you don't already own and your friendly dealer wants’ a LOT more markup on those then he did on the original tractor. Welcome to EBay etc. and your local flee trader. Patience is not only a virtue but will also save you lots of money.
or break out the welder, grinder, saw, duct tape, and redneck ingenuity
   / new guy with a 5055E #15
you have a nice looking tractor there.an its always fun to have jobs for them.
   / new guy with a 5055E #16
Thanks. Of course great minds think alike.:rolleyes:
Two bits of advice. One check all your radiator hose clamps and snug them up if you can ,now and again at 50 hours. The 50 hour check is in the owners manual but I didn't come on to it until I had a leak at about 100 hours. Second keep your ROPS up whenever your using the loader. You may only need it once but once is enough. Don't forget to put it back down before putting it in a garage if the door isn't high enough. When I build a garage for mine the doors will be plenty big enough as mine has a canopy and soft cab so it is always up.
I have heard of the lose clamp problem before, but had forgotten about it. this is the first tractor i've ever had/used with a ROPS, and it's a good idea to keep it up, but i find myself under trees fairly often so it remains down
   / new guy with a 5055E #19
Definitely check the hose clamps...mine leaked at about 16 hours
Sent from my LGL35G using TractorByNet
CATERPILLAR 96" HANG ON WHEEL LOADER FORKS (A52709)
CATERPILLAR 96"...
ALLMETAL MOBILE PRESSURE WASHER (A58216)
ALLMETAL MOBILE...
PALLET OF MISC (A58374)
PALLET OF MISC...
2016 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A56858)
2016 Peterbilt 579...
Deere 310L (A53317)
Deere 310L (A53317)
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
