Internal Retaining Ring Tool
   / Internal Retaining Ring Tool #1
BenH
Member
Olalla, WA
Kubota L5030
I am in the process of removing the steering cylinder on my Kubota L5030 for repair. I am in need of a good internal retaining ring tool. The one I have, which is one from Harbor Freight will not compress the ring enough to remove it. Any recommendations for a tool that will work? I think the retaining clip will accept around a .126 tip. I just don't want to keep trying with inadequate tools and maybe damaging the clip. Then I would be in a serious bind.
The retaining clip I am attempting to remove is the one that secures the steering cylinder into the axle housing rings that the cylinder slides into.
Thanks for any suggestions.
Ben
   / Internal Retaining Ring Tool #2
Napa used to sell a very nice unit that was internal and external with different angle and pin(size) inserts. Google "snap ring pliers", lots of hits.
I would think any "quality" tool dealer would be able to get you one. I think mine cost was about $85, but they are 17 years old now and still work very well.
Thanks Rayster,
I did Google "snap ring pliers" and there are plenty to look at. The problem is that I have no idea which will work. The ones I have are either too flimsy or just will not compress the internal ring enough to remove it. I will keep looking for a quality tool that will compress the ring enough to remove.
Much appreciated.
Ben
   / Internal Retaining Ring Tool #4
There is a set of internal only at MATCO TOOLS. Maybe you can get on the phone and call some of the tool companies.
Thanks, I will check it out.
   / Internal Retaining Ring Tool #6
Some years ago, I finally threw away the junk snap ring tools I got from the Homier traveling tool sale, when I got a set of Matco tools for both internal and external rings.
   / Internal Retaining Ring Tool #7
I've had good luck with this style tool.
   / Internal Retaining Ring Tool #8
I've been real happy with several snap ring plier made by KD & bought from local NAPA stores. They weren't cheap, but they've lasted and lasted and work fine. Different types & sizes are required for different size & type snap rings. Some are tiny & slender while some are big & require a lot of force to deform. Example: old typewriter (?!?) vs truck transmission.
https://www.google.com/search?q=kd+snap+ring+plier&safe=active&rls=com.microsoft:en-us:IE-Address&source=lnms&tbm=isch&sa=X&ei=4IhyUsTuGqj_4AO954HYAQ&ved=0CAkQ_AUoAQ&biw=1044&bih=909
I will be checking the local NAPA store as well as a few other stores today. The snap ring I am removing is pretty stiff and set into a deep slot so it has to be compressed completely to be removed. This is a picture of the ring….
   / Internal Retaining Ring Tool #10
Snap ring pliers is the common name for the tool. As others here have said you can buy a quality name and pay a quality price or, because this tool doesn't get used that often unless you're in the business, I recommend buying any brand but get a pair that's at least 8" or bigger. The bigger size will give you the power you need to get off the most stubborn snap ring. If possible, get one with 2 holes in the body so you can use it as both an inner and outter ring tool. Sears would be a good place to find one reasonably priced. Good luck...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2022 Chevrolet Tahoe FL SUV (A55853)
2022 Chevrolet...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
flooring (A55758)
flooring (A55758)
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
