You are incorrect.  I'm not talking about the wheel bearings, I'm talking about the outer stubshaft bearing that is inside the spindle.  The spindle must be removed to get to it and a special tool used to remove it.  It runs on the axle with no race, so if it fails the outer shaft must also be replaced.  Once you are that far into the project the axle can simply be pulled out.  This is a good idea if you want to check on the Ujoints or if you don't have greaseable joints.
This bearing might not last as long as the wheel bearings and should be serviced early enough to prevent more down time and much more cost and hassle.  When mine failed it also ruined the locking hub.  So I ended up buying a new locking hub, a new stubshaft, new bearing and doing a job much harder than simply greasing wheel bearings.  Now, sometime later, I've got a wheel bearing making noise.  So I'm faced with doing the whole thing once again, as I can't let the axle support bearing go ungreased while doing the wheel bearings.
For anyone going into this for the first time, be sure to go ahead and replace the ball joints.   AVOID Moog.
