Where to plumb for heater
   / Where to plumb for heater #1
athomp
I want to install a heater core in my 5740. Can anyone tell me where to tap into the cooling system for this? Thanks
   / Where to plumb for heater #2
Dayco supplies many nice tap valves (on/off/in between). Tap into line from engine to rad (fluid prior to entering top of rad).
   / Where to plumb for heater #3
Wrong.
To supply a heater core.High temp, high pressure coolant is sent to the heater and coolant returns to lowest pressure point of the cooling system .
Tap in the supply in the engine side of the thermostat. Return heater core line to the water pump inlet.
   / Where to plumb for heater #4
Wrong.
on a Montana engine side of t-stat??
   / Where to plumb for heater #6
...except liquid cooled engines designed with reverse coolant flow.
Does anyone have or know of any photos that show it on this particular engine?
   / Where to plumb for heater #9
Not a whole lot of those reverse cooled engines in standard mid priced production vehicles and equipment. It is a superior cooling system however. iirc Chev ran off a batch of performance reverse cooled V8's in the mid 90's ?
   / Where to plumb for heater #10
I dunno. But they do exist. Hot-rodders do it sometimes. So "any liquid cooled engine" isn't entirely accurate.
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
