Engine oil
   / Engine oil #101
He didn't say he knows more about auto designs than auto engineers. He said in his last post, and the 2 or 3 previous posts he made, that the vehicle "parts ways" from it's owner for every reason in the book, but not because of the lack of synthetic oil. Be it rust, transmission, accident, or trade in, I think he's 100% correct.
Obsessing over engine crankcase oil seems to be a common irrational behavior oddity for some males, on internet sites. If common sense was truly "common", then one would be more worried about posting of bad weather or, bumps in the road- both are more apt to impact the longevity, and devaluation of your vehicle.
That's exactly my point. From a common sense stand point I guess it's hard to understand folks who believe "if this is more than enough then even more would be better". I never intended to say there was no benefit to synthetic. I'm just saying the benefit isn't necessary to take your engine well past the life of the vehicle. As someone mentioned earlier, if you extend drains or you live in an extremely cold environment then synthetic may be for you. Other than that any benefit you gain (if any) will someday be sitting out in a salvage yard.
   / Engine oil #102
Out of curiosity, what kind of vehicles do you drive?
   / Engine oil #103
2 examples. Volvo 5 cylinder turbo "Whiteblock" (used in the 1999-2004 S70, V70, etc) and the VW 1.8L Turbo (used in various cars between 1998 and 2004).
Both cars if maintained to OEM oil change intervals (Volvo was every 7500 miles with Dino oil) WILL build up sludge in the engine by 100k miles. On the Volvo it will block the passages in the head starving the cam of oil. On the VWs there was a class action lawsuit over it which resulted in a settlement.
Switch to Synthetic with the same oil change intervals and no sludge.
My car ('97 Volvo V90, straight 6, non-turbo with hydraulic lifters) was significantly quieter after I switched to Mobil1 Synthetic and there have been issues with the lifters getting "stuck" when using dino oil.
Aaron Z
   / Engine oil #104
I drive a GMC turbo diesel (LBZ dually)
My better half drives a Z06 Corvette and a GMC Yukon. I tend to stay American.
The truck has about 230k plus hard earned miles towing a 37' Carriage fifth wheel all over the US.
I also had a 2001 Chevy LB7 Duramax that I sold to a close friend. He leases it for hotshot service and the last time I talked to him he said it was bumping on 400k. It's been a great truck and he says it doesn't use a drop of oil. He plans on keeping it to see just how long it will go. It's racking up miles real fast.
   / Engine oil #105
2 examples. Volvo 5 cylinder turbo "Whiteblock" (used in the 1999-2004 S70, V70, etc) and the VW 1.8L Turbo (used in various cars between 1998 and 2004). Both cars if maintained to OEM oil change intervals (Volvo was every 7500 miles with Dino oil) WILL build up sludge in the engine by 100k miles. On the Volvo it will block the passages in the head starving the cam of oil. On the VWs there was a class action lawsuit over it which resulted in a settlement. Switch to Synthetic with the same oil change intervals and no sludge. My car ('97 Volvo V90, straight 6, non-turbo with hydraulic lifters) was significantly quieter after I switched to Mobil1 Synthetic and there have been issues with the lifters getting "stuck" when using dino oil. Aaron Z
I could add to that most any ohc Chrysler or Toyota from the '90's-early 2000's.
Those just about all sludge up on Dino, but not synthetic. At nearly any interval.
   / Engine oil #106
Aaron Z
If there was a class action lawsuit and VW was held accountable then the problem was vehicle related. Bad designs can and will cause sludge. Keeping vehicle oil at optimum temp is the key to prevention. Any oil will sludge if temps aren't maintained high enough to cook off acid promoting condensation. Short trips are considered severe service due to this. Either way it isn't oil related or the problem would be widespread across other mfg's.In this case of bad design I can see where synthetic may help to bandaid the root cause of the problem. However, synthetic contains more varnish than dino so if it doesn't stay hot enough it will present it's own set of issues. Likely not as bad as sludge but worst considering varnish. That's why I referred to it as a bandaid.
   / Engine oil #107
The problem with VW was that the oil got too hot and dino oil broke down before the recommended change interval (per the stories I read), then VW would claim that the owner hadn't changed their oil often enough and refuse to cover the damages.
Aaron Z
   / Engine oil #108
Aaron Z
Got ya... So basically it was burning the oil. Thanks for clarifying!
1839 (A51248)
1839 (A51248)
UNUSED LANDHONOR LHR-SP100 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2012 Club Car Electric Cart (A53424)
2012 Club Car...
42013 (A51691)
42013 (A51691)
