I HAVE A`` L345 DT KUBOTA``.(.WATER IN THE HYDROLICS SYSTEM).
   / I HAVE A`` L345 DT KUBOTA``.(.WATER IN THE HYDROLICS SYSTEM). #1
hotrod12
montreal quebec
l345 dt
IT IS THE THIRTH TIME I CHANGE OIL..FLUSH THE PIPES..THE OIL IS STILL WHITE-GREEN.....I CHECK OIL FILTER (IT IS ONLY A METAL FILTER WHITH VERY SMALLS HOLES)DURING THE WINTER IT COME ALL FREEZE AND THE HYDROLICS SYSTEM JAM ...I HAVE TO CLEEN IT....WHAT CAN I DO TO RESOLV THE PROBLEM....IS THERE AN OTHER FILTER ON THE SYSTEM..THANKS.....MARIUS.
   / I HAVE A`` L345 DT KUBOTA``.(.WATER IN THE HYDROLICS SYSTEM). #2
First thing is to stop the water ingress.
If not stored inside, use a good tarp.
Flush the system until the fluid looks clear. Use a mix of diesel, isopropyl alcohol, hyd fluid.
Some hyd filters will absorb some water.
   / I HAVE A`` L345 DT KUBOTA``.(.WATER IN THE HYDROLICS SYSTEM). #3
Be sure the trans/hyd filler breather cap isn't plugged. I once owned a K-ubota M4900 that was intended to to have a horse shoe shaped hose on the filler cap for a breather that the hose was lost and rainwater was entering the hyd system
Thank for the help. But i got another question.
What is the proportion of the mix of diesel, isopropyl alcohol, hyd fluid? and the quantity?
Is that true that the isopropylic alcool can dried the seals if you put too much?
   / I HAVE A`` L345 DT KUBOTA``.(.WATER IN THE HYDROLICS SYSTEM). #5
This is an excerpt from Soundguy and he has been doing tractors for a long time.
Excerpt:
1 quart atf ( type f or dex/merc 3 ) to 1g diesel, to 1 pint 90-91% rubbing alcohol. I'll put that into a sump as a rinse. if it needs more fluid for some pickup.. I'll add in some cheap utf or more diesel rinse mix.
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
