   / Harbor Freight Tools that don't suck #3,801
I see you're in N.H. too. Where did you find a HF store? According to the "find a store" map on their website, other than 2 stores in Maine they have zero presence in New England. To be honest, before this thread I'd never heard of them.
I wonder why they're avoiding us.
I see two in NH - Nashua and Salem - there are a few in Ma that I know of - Hyannis, New Bedford, also in Warwick RI and at least three in CT.
   / Harbor Freight Tools that don't suck #3,804
I want to give a thumbs up on the HF 66984 3/4" impact wrench. My 1/2" wrench cannot handle the lug nuts on my Dodge pickup. I was in need of a larger wrench. Going larger also meant spending big bucks. That is until I saw this model at HF earlier this year. I paid 70-80 dollars with a coupon can't recall exact price. I have been very satisfied with it. It has plenty of power. I have to be very careful when installing lug nuts as I can easily over torque the nuts. I usually tap the trigger to just seat the nut then just a couple of taps to torque. Today I rotated my tires and tapped the nuts a few more times. I found many of them over torqued. I torque to 135 ft. Lbs. The only down comment I have is that it is a bit heavy. It also uses 7 CFM of air so a good compressor may be needed.
So if you are in need of a larger impact wrench check this one out.
   / Harbor Freight Tools that don't suck #3,805
What kind of compressor do you have?
   / Harbor Freight Tools that don't suck #3,806
I have a Craftsman 30 gallon with 9.9 CFM at 90 PSI. I just wanted to pointed out the 7CFM at 90 PSI requirement. My compressor handles the tool with no problem.
   / Harbor Freight Tools that don't suck #3,808
I don't know about the tumblers, but rock tumbling should teach them about "delayed gratification."
How Long Does Rock Tumbling Take? | Rock-Tumbler.com
The short answer: Using a rock tumbler to convert rough rock into polished stones can take as little as one week to as long as two months.
Bruce
   / Harbor Freight Tools that don't suck #3,809
The most important thing in tumbling is finding rocks without any crevices. If you do so, the crevice can, and usually does trap the coarse grit during the tumbling cycle. You may not notice it when you rinse the stones as you prepare for the next tumbler charge. In the next cycle or two of tumbling, the coarse grit becomes released from the stone, and scratches the whole batch. You've now wasted all the time and money spent, not to mention the rocks.
   / Harbor Freight Tools that don't suck #3,810
I have seen the tumbler in action and read the instructions. It takes a lot of effort for miniscule results. Basically, you will use it one time and it will then sit forever in a state of suspended animation until you or your wife donate it to the thrift store.
   / Harbor Freight Tools that don't suck #3,811
It takes quite a while to find enough of the right rocks to fill a tumbler, unless you have a special source. I bought mine at a thrift store, 30 years ago, and I used it one time.
   / Harbor Freight Tools that don't suck #3,812
Still got it or already donated to the thrift store?
   / Harbor Freight Tools that don't suck #3,813
I still have it, although it is a bit different than current models; it still works quite well. I used it to clean some small bearings.
   / Harbor Freight Tools that don't suck #3,814
The source of rocks is not a problem. My kids are constantly bringing home "special" rocks that they have found on various outings. Thank you to all for the cautions about delayed gratification. I'm considering the tumbler since so many of the brainless toys we have given in the past are lying unused in the bottom of closets and on shelves. The delayed gratification may be a good thing.
   / Harbor Freight Tools that don't suck #3,815
bought the bearing separator set today. used it to pull the head stock and table off a rusted old drill press column. worked great.
   / Harbor Freight Tools that don't suck #3,816
Any feedback on the rock tumblers?
Item 67632 Dual Drum Rotary Rock Tumbler
Item 67631 Rock Tumbler, 3 Lb. - Save on this Rotary Rock Tumbler
I'm thinking of getting one or the other for my kids for Christmas. Do the tumblers come with a grit starter pack?
There are a lot good reviews of the rock tumbler (single) and many people are happy with the performance. Mine rapidly broke the first 0-ring type belt and then proceeded to break the 2nd one too. The reviews say the alignment between the pulleys is critical. I also think you would be wise to keep plenty of spare belts and the pulleys on hand. I ended up using large rubber bands to finish my polishing cycle, changing the rubber bands daily because they wouldn't last any longer. I love the results as far as rocks go. Read the instructions well and follow them. Grits are readily available on eBay, but the first grits are fine for a beginning. Don't be afraid to exceed the times for tumbling. If it says 10 days, go 12 days or 2 weeks. As bcp mentioned, this hobby will teach your kids patience. The results are worth it. You can turn average rocks into really beautiful gems. Mine is a cautious thumbs-up. Setting up and aligning the polisher is critical.
   / Harbor Freight Tools that don't suck #3,817
I wonder how someone figured out the optimum rotation speed for a tumbler.
Could you make it go faster?
Gee Dad, this is, like, nice, but two weeks?
I'll be, like, so old by then...:D
   / Harbor Freight Tools that don't suck #3,818
Since I have tried the rock tumbler, used it once and was flustered at every turn, I think I found a solution.
I was at the local Thrift Store this morning and there was a bag full of nicely polished stones. Maybe 25 or 30 of them and the price was a steal for 35 cents. That's my first choice for any future time when I feel the desire to have small polished rocks.
   / Harbor Freight Tools that don't suck #3,819
c'mon SixDogs, it's the journey not the destination...
round and round and round and round and round and round....
   / Harbor Freight Tools that don't suck #3,820
Let the kids put the rock in the tumbler, then while sleeping, exchange them for the polished ones :)
2007 Volvo VNL Truck Tractor (A61306)
2007 Volvo VNL...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2016 Deere 180G (A60462)
2016 Deere 180G...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2017 John Deere 825i XUV Utility Cart (A59228)
2017 John Deere...
