Newbee looking at Yanmar 2210 VS Yanmar 2820? I have questions?
   / Newbee looking at Yanmar 2210 VS Yanmar 2820? I have questions? #12
Here is an explanation of the overrunning clutch. If a tractor doesn't have it, then when you mash the clutch, the inertia of the spinning mower blades turns the PTO shaft, which pushes the tractor forward.
TractorData.com - Overrunning PTO Clutch
They cost about $50 at Tractor Supply.
Thanks for the replies. I will be buying their loader and hopefully a pose hole digger taht they sell new for $550.00. Thats all I will be able to get at first but the craigslist around here are loaded with farm equipment. I see all kinds of adds for "3 point" this and " 3 point "that. I have a question are all "3 points" the same. Some items asy things like a "CAT THREE POINT"?
If I am searching for implements what type of 3 point items am I looking for, for this Yanmar. And what do guys find to be the most common items you need. I would love a backhoe but its just not in the financial cards riight now. Maybe down the road.
Thanks RUMBLON
   / Newbee looking at Yanmar 2210 VS Yanmar 2820? I have questions? #14
For subcompact, compact, utility and farm tractors, there are four main classifications of 3 point lift systems. Category 0 (which is what the smaller subcompacts use), Category 1 (which is what the compacts and some of the larger subcompacts use) and Category 2 (used by some utility size and most farm size tractors). Some of the larger "compact" tractors and utility tractors have 3 point lift that are rated for Category 1 or 2. Category 4 is used by the big boy tractors (probably 150hp and over, but I'm not sure).
I know nothing about these Yanmars, but I would assume they are both Category 1. Call the seller and find out for sure.
   / Newbee looking at Yanmar 2210 VS Yanmar 2820? I have questions? #15
You assume correctly. Cat.1
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
UNUSED JCT 60" HD HYD CONCRETE MIXER (A51248)
UNUSED JCT 60" HD...
2021 JOHN DEERE 8R 370 LOT IDENTIFIER 175 (A53084)
2021 JOHN DEERE 8R...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
