ROPS Tubing: Drilling Holes
   / ROPS Tubing: Drilling Holes #61
If the dealer lost, I dont see how he could have actually billed the storage fees..
   / ROPS Tubing: Drilling Holes #62
I better go check my drill bits
I tried to drill a hole thru the very top to mount a light fixture
The hardest metal I have ever tried to drill thru
I gave up------ I have tie straps holding my lights on top- UGLY
   / ROPS Tubing: Drilling Holes #63
Try cobalt bits and cutting oil. Go slow speed.
   / ROPS Tubing: Drilling Holes #64
It was bugging me so I gave it another shot last nite/started out with very small bit- bet I used 6 bits until I got it up to a 3/8 hole---- whew ! Tough metal !
   / ROPS Tubing: Drilling Holes #66
If you don't make chips with the drill bit fast enough, the heat goes into the tube steel, and not the chips, causing the tube steel to air harden. This happened to me while drilling holes to bolt hooks to my loader bucket. I'm not a machinist, but there is an optimum combination of "feeds & speeds" that will avoid this. Also, dull drill points will almost insure that your work piece will harden as you drill. Sharp bits are cool bits.
   / ROPS Tubing: Drilling Holes #67
Your first statement makes no sense.
Of course it does.
Drill one hole in the center (any of the four sides).
Ok, it's in the center of the beam structure when viewed from that direction.
Ok, now swing your view point around 90 degrees and view your beam structure.
Voila! It is now in the 'edge' of your beam structure.
So depending on the actual force placed upon the beam structure, it is either on the center face or the side 'edge'.
Center and edge is dependent on the force applied in this discussion.
   / ROPS Tubing: Drilling Holes #68
One of my customers is a machinist and he gave me a coffee can of small short cnc bits that were used. These little boogers do a great job starting holes wish I had some of these in larger sizes.
   / ROPS Tubing: Drilling Holes #69
Of course it does.
The hole is still at the center of the tubing...viewing it from 90 degrees doesn't move the hole from the center of the ROPS tubing...but rather then straight on, you're just viewing the hole's opening from the side. Matter of perspective...
   / ROPS Tubing: Drilling Holes #70
A small hole is probably not going to hurt anything but why risk it, your life could depend on the ROPS. I think there are better ways to attach stuff to the ROPS than drilling.
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
