John Deere 955 not getting fuel past injection pump
   / John Deere 955 not getting fuel past injection pump
just an update....got my rebuilt pump and injectors put back in and it started up and ran great. My injector was seeping around the base for about the first 10 minutes, then stopped, not sure if this will be an issue later on or not. I did notice my front main seal leaking, so I will look into replacing this next. If I recall correctly, these are replaced fairly easily from the front.
   / John Deere 955 not getting fuel past injection pump #22
Yes... it's just a seal in the gear cover. When I rebuilt mine, the harmonic balancer had a groove worn in it wher the seal rode on it. I had to install a Speedi sleeve on the balancer or the new seal would have no chance of sealing.
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
FENCE PANELS (A58216)
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2019 GALYEAN...
2019 C.GALLEGOS PNEUMATIC TRAILER (A58214)
2019 C.GALLEGOS...
