Another tractor fatality
   / Another tractor fatality #2
I'm sure it seemed like a good idea to him at the time. Really not enough information to tell what exactly went wrong other than the dangers of doing something alone that should have a minimum of two.
   / Another tractor fatality #3
Hard to tell what happened, but seems unusual to tip over pulling a car (you'de presume it was on level ground), maybe it went off the road while he was looking back at the car? Shows how dangerous things can be, even doing something that's relatively simple and you'd imagine also on level ground is dangerous.
   / Another tractor fatality #5
Saw that this morning reading the news. There will probably be an update later with details. I guess it wouldn't be hard to do with a narrow front tractor, or the towed vehicle started and took the slack out of the chain, then the tractor took up the slack and got jerked somehow.
   / Another tractor fatality #6
Reading the brief article, it would appear there were two people at least. Assuming the reporter got confused (as they usually do) between "jump-start" & "pull-start". I don't see how a tractor could tip over while jump-starting a car and pull-starting would require a second body in the car. Maybe the person in the car didn't know what they were doing and rammed the JD when the engine caught? Lot of possible scenarios for this one. Sad, whatever the cause.
   / Another tractor fatality #7
Failure to use the parking brake on the tractor while attempting a jump start?
   / Another tractor fatality #8
I Googled another article, and it said he was pulling the car with a John Deere tractor, trying to "jump start" it when he lost control.
   / Another tractor fatality #9
Yeah, that's what the article said. But knowing how 99% of reporters call any large, yellow construction machine a "bulldozer" and anything with a trigger an "assault weapon" I made the assumption this one didn't know what he/she was talking about either.
   / Another tractor fatality #10
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
