ROPS Tubing: Drilling Holes
   / ROPS Tubing: Drilling Holes #71
A small hole is probably not going to hurt anything but why risk it, your life could depend on the ROPS. I think there are better ways to attach stuff to the ROPS than drilling.
Yep...U-bolts for lights and most hardware, wire ties for any wiring.
   / ROPS Tubing: Drilling Holes #72
Of course it does.
Drill one hole in the center (any of the four sides).
Ok, it's in the center of the beam structure when viewed from that direction.
Ok, now swing your view point around 90 degrees and view your beam structure.
Voila! It is now in the 'edge' of your beam structure.
So depending on the actual force placed upon the beam structure, it is either on the center face or the side 'edge'.
Center and edge is dependent on the force applied in this discussion.
For a bending load, I'm with you.
At right angles to the applied load it will see a very small stress as it's centered on the neutral axis.
Spin it 90 degrees and it will at the "furthest fiber" location and seeing either max tensile or compressive load.
This is assuming simple beam loading.
If there's torsion - twisting - then it will be loaded in any load orientation.
Drilling the ROPS is going to be a crap shoot, as you never know how it's going to be loaded while it's in the act of keeping the tractor from crushing you.
   / ROPS Tubing: Drilling Holes #73
Small holes can create higher stress risers than large holes, so making a hole smaller doesn't necessarily make it less of a threat to the structure. If you're going to drill it anyhow, I'd suggest a smooth hole with a chamfer on both sides and no threads. If you need to thread it, then consider drilling a larger hole, blending/chamfering it, and using a Rivnut, PEM clinchnut, or similar, to get the threads you need. More hassle, but much less damaging to your safety gear.
   / ROPS Tubing: Drilling Holes #74
Came across this thread and it occurred to me that no one must have ever looked at the certification tag on their ROPS. They always have a maximum weight rating. I was watching a show about the Cat D11R and they were driving over a steep bank letting it slide sideways a little bit, not enough to roll it, but they said not to worry, the ROPS is designed for 1 1/2 times the weight of a D11R. So, yes they are designed so that loaders, backhoes, implements and weights can be added without compromising the integrity of the ROPS. I've also seen tags that say this ROPS was designed for roll over protection but was not tested. Apparently testing ROPS to get the certification is a very costly process, ie/ a cash cow like most things that need certification.
As far as holes, a couple little holes for lights in the top corners aren't going to affect the structure of the ROPS. I think a bigger concern would be getting water in the ROPS if it is welded solid. I say this because one of the square tubes on the ROPS on my Cat is expanded and split along one corner. I don't know how water got in there but that's about the only way it could happen. I also have a factory installed quick attach backhoe. For the backhoe they added extra grab handles onto the ROPS. They didn't drill through the ROPS though. They welded short threaded round bar pieces for bolting the extra grab handles to. Welding something like that or a mounting tab might be a better option than drilling into a ROPS. If putting a couple holes in steel is such a bad thing and causes all this stress, how come there aren't millions of low boy trailers being impounded because of the holes in the main frame? :confused:
   / ROPS Tubing: Drilling Holes #75
And did you happen to notice that that safety info plate your talking about is riveted on.
   / ROPS Tubing: Drilling Holes #76
Maybe that's why it costs so much to get them certified???:D They're worried the rivet holes will cause cracks.:laughing:
   / ROPS Tubing: Drilling Holes #78
I'm surprised no one suggested velcro to stick stuff on rather than drilling...(heh heh)
I love that stuff! I just wish I was the person the developed it.
   / ROPS Tubing: Drilling Holes #79
I really don't think that drilling a couple of holes in the ROPS will weaken it enough for it to fold up or bend over and collapse. For sure not on the smaller BX tractors.
   / ROPS Tubing: Drilling Holes #80
Structurally speaking a round hole (clear of burrs and nicks) will not weaken a structural component.
Example is an aircraft wing spar that they drill all sorts of holes to lighten the structure.
Naturally not to exaggerate. A 1/4" hole in a 2" tube would be negligent but a 1 3/4" in that 2" would be a disaster looking to happen.
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
