Fireplace Question
   / Fireplace Question #1
B7510HSD
Kamiah,ID
Kubota B2601
Can you put a propane insert in a normal fireplace???? Our current fireplace has a heatolator with fans on it would this need to go away??? It would be nice to use the fans as one goes to the master bedroom!!!
   / Fireplace Question #2
Generally, yes you can. Have a stove installer look it over and you will have a better idea.
Technically, you need a licensed gas plumber for the propane installation.
Thanks for the info guess maybe the propane company may know someone!!
   / Fireplace Question #4
They would, but for the stove itself and how it will fit in the existing fireplace opening, I would rely on a stove shop that sells propane stoves. They will have a licensed person for gas, and will be able to tell you if you need to make any changes to the flue also.
Do you have an existing outside air supply for the fireplace? Propane stoves can be installed with a double walled flexible flue that is run inside your existing chimney. One portion of flue pipe is outside air supply the other is exhaust. I think they can go 25' in length/height with this.
No no outside air supply it's an old brick fireplace right in the center of the house but the chimney is only about 15 ft max to the top maybe less!!
   / Fireplace Question #6
I think the challenge is going to be making use of the heat-o-later ducting with the propane insert. I haven't seen a heat-o-later in decades and I don't know what the insides look like.
They make some sweet little cast iron propane stoves. They look just like the same model in wood stoves. No fans, quiet, may have to extend your hearth though and you want to use the heat-o-later ducts. If you can't do that, it is an alternative. Heck, put one in the bedroom while you are at it. :laughing:
Well not sure how big the hearth has to be but it is about 12 to 14 inches out now!??
Not so sure I would like the look of that in front of the where the fireplace is now our fireplace is pretty good size!!
   / Fireplace Question #10
It would look different. They do look better in a space that was designed for a stove IMO.
Propane stoves can use quite a bit of propane. A gallon of propane has about 91,000 btu's. A 30,000 btu stove would use a gallon roughly every three hours, is the way I understand it. If you burn it 6pm to 6am, 12 hours, that's four gallons per day, 120 per month.
53ft trailer Vin IUY VS2532 7M0152 01 VS2RA (A51694)
53ft trailer Vin...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2017 FREIGHTLINER...
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
JOHN DEERE LOT NUMBER 124 (A53084)
JOHN DEERE LOT...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
