To you 8560 owners
   / To you 8560 owners #11
I got the timing advanced see if that helps it tomorrow. Thanks for all the help.
   / To you 8560 owners #12
Ok so which way is advancing the timing rotate pump away from engine or toward? Is this a common problem?
Rotate the top of the pump toward the engine, basically just enough to misalign the chisel marks, and if there are no chisel marks, put them in before you start.
What Galen L said is exactly right. The problem is fairly common I think. Others, including myself had it on 7520s. If its that on yours you should see it disappear - or practically so ... depending on if you didnt go quite far enuf. After youve got it right be sure to re snug all the flange bolting and tighten the attachment well at the "rest" bracket on the back end of the pump. [mine came loose at that bracket later]
larry
   / To you 8560 owners #13
Keep us posted on this. Mine smokes a little at idle, It goes away as soon as you rev it up a little.
   / To you 8560 owners #14
Run it today seems to have helped it no white smoke at all. Very simple fix thanks for all the help now I can do the 5530.
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2016 Club Car Carryall 500 (A50121)
2016 Club Car...
1965 Great Dane 40' Flat Bed Trailer (A50121)
1965 Great Dane...
Cattle Chute (A50121)
