What to look at in a used bush hog
   / What to look at in a used bush hog #1
QBH
Alachua, FL
Yanmar 2210D, Kubota BX25D, Gravley PM260Z ZTR
I am going to look at a used BH tomorrow. The price is pretty good, and the guy says it is in good shape, but how can I tell?
Other than obvious cosmetic stuff, rust etc, what do I check?
Should it come with a drive shaft, or is that usually an additional purchase?
Anything else to consider?
Thanks
Larry
   / What to look at in a used bush hog #2
Check the oil in the gear box for water, look on the ground underneath the gear box for oil leaks, look for broken welds on the deck, bent or beat up blades.
If it did not come with a drive shaft I would expect the price to be adjusted accordingly.
   / What to look at in a used bush hog #3
Drive Shafts with safety covers are expensive!
   / What to look at in a used bush hog #5
Many of the transmissions will have a small inspection plug you unscrew to check the oil level in the transmission. Oil should run out or be at the level of the inspection plug hole. You add fluid at the breather/plug on top of the transmission. Does the oil look like milk? meaning water in the fluid. No oil at all? Some people put corn head grease in the transmissions because the seals wont hold oil anymore. This is easier than replacing the seals. Take a small adjustable wrench with you. The drive shaft runs from 125 to 250 bucks. depending on length and where you buy it. It should have a shield for safety. Lot of people take them off because it makes greasing the U joints more difficult. But people do get hung up in the drive shafts, just how I don't know but it happens.
   / What to look at in a used bush hog #6
Don't do what I did and fail to notice that the previous owners sheared the shear bolt off the gearbox input shaft and rammed the PTO shaft further down the shaft. It took me a whole day of cutting (albeit with the wrong tools) to get the old shaft cut loose and a new one installed.
New PTO shaft was only $70 from agri-supply though, no big deal.
   / What to look at in a used bush hog #7
Related to this (thanks for a good question!), the bushhog I have is coated with rust on the underside. Now, I know there is a difference between surface rust and what I call "RUST rust" (own a steel horse trailer) but what should I do about this (recently got, now stored slightly elevated)? Is a coating of rust NBD on a '94 model? Top is getting repainted. Sorry, not intending to hijack.
   / What to look at in a used bush hog #8
If at all possible, have the seller rig it to his tractor so you can see how well it works or if there are any unexpected noises....if you're no familiar with rotary cutters, they all make some racket initially.
Wow, good tips all.
Thanks for the suggestions!
Roy, I like the plan. I was thinking of taking my tractor down there, but my trailer isn't long enough to haul a tractor with a bush hog attached, if I buy it. In that regard, will a 4' bush hog fit in the back of my wife's F-250?
Larry
   / What to look at in a used bush hog #10
Larry
I measured 2 brands recently. Both were 54 inches wide overall.
Bruce
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2012 IC Corporation PB105 Passenger Bus (A48081)
2012 IC...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A48082)
2024 Bintelli...
