Yanmar ex3200 or Kioti Ck30HST
   / Yanmar ex3200 or Kioti Ck30HST #11
Fuel efficiency edge goes to the Yanmar engine, its direct injection and has a larger bore and shorter stroke. With those two factors you're going to use less fuel which will probably negates the slightly smaller tank. You haven't said how long you plan to keep the tractor, but my money would be on the piston rings and bearings lasting longer in the Yanmar before a rebuild is needed. Of course, I'm slightly biased towards that brand. :D Enjoy whichever tractor you choose!
   / Yanmar ex3200 or Kioti Ck30HST #12
My Bobcat CT235 (CK35) used right at 1 GPH.
Sent from my GT-P3113 using TractorByNet
   / Yanmar ex3200 or Kioti Ck30HST #14
When do you get it?
   / Yanmar ex3200 or Kioti Ck30HST #16
Congrats on the new tractor.:thumbsup: Even if i did wish you would be a new Yanmar owner.
Here's the pics of the new tractor, drove it off the lot on Friday
   / Yanmar ex3200 or Kioti Ck30HST #18
Lookin good!
   / Yanmar ex3200 or Kioti Ck30HST #19
I think the EX3200 is very similar to John Deere 3005. Yanmar builds the 3005 for JD.
The CK30 is good tractor but a common problem with them is the sticking hydro pedal.
POST YOUR INFO on the common problems you speak of with the CK30 sticky hydro pedal?I would like to see all of your information.
   / Yanmar ex3200 or Kioti Ck30HST #20
congrats on the new Kioti. Welcome to the Pack! I used mine to blow snow today. Still love it after nearly 8 years now.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2844 (A54757)
2844 (A54757)
New Holland 325 Manure Spreader (A55218)
New Holland 325...
