Coolant change on BX 2660
   / Coolant change on BX 2660 #1
kylied
Time to change the coolant on my BX 2660 is there a drain plug/petcock valve that allows for draining?
   / Coolant change on BX 2660 #2
I don't know about your BX2660, but I just changed the coolant on my BX23. On the BX23, there is a little black plastic plug on the right side of the radiator at the bottom. By "right" side, I mean right when you're sitting on the tractor. It requires a flat bladed screwdriver to loosen it.
Your 2660 may be different, and probably is since the BX23 has the D905 motor and the BX2660 has the D1005, but there is certainly a plug or valve to allow for draining. My owner's manual showed how to do it. Do you have a manual?
I do not have a manual, I'll check out what worked for you and see if it applies to the 2660
   / Coolant change on BX 2660 #4
Mine has a rubber plug over a nipple on the radiator.
Sent from my GT-P3113 using TractorByNet
   / Coolant change on BX 2660 #5
For my BX-25 and my Polaris ATV, I found the easiest and quickest way to drain the coolant was by disconnecting the lower radiator hose from the radiator.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
197711 (A51244)
197711 (A51244)
2025 CFG 48in Forks and Frame Skid Steer Attachment (A50325)
2025 CFG 48in...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
