Advise on Old Barn
   / Advise on Old Barn #1
jdjdjd
Bonham, Texas
Kubota M9540 Grand Cab
Recently purchased property with an old pole barn. Today I went out and found this:
No plans to rebuild but wondering if is better to hire someone to tear it down and remove the debris or if I should try to salvage some of the posts and sheet metal?
JD in Texas
   / Advise on Old Barn #2
I would try to salvage the metal and the toilet. There is enough metal there you would probably get a few hundred worth of scrap.
   / Advise on Old Barn #3
If you have a foreseeable use for the posts for fencing or whatever, some posts, or parts of some if they are cracked, would be worth saving.
Same with the tin I guess. You could stack it up and run a craig's list ad or the like. Or scrap it.
Did the recent snow and ice cave the roof in? It's heavy stuff.
   / Advise on Old Barn #4
I'm with the previous posters, I would save what looks to have some life left. Roof panels look pretty gone, but sides look OK. Post are always nice to have laying around. I sure would keep that meter pole, some cash right there.
No snow, just freezing rain and sleet. Lots of weight.
Went out this morning with the tractor to break ice on the ponds. Barn was OK then. Went back this afternoon to feed steers and barn was down.
I will have to wait for the ice to melt before I can go inside and look around.
Just trying to figure out how to dismantle it safely.
Now I am thinking there might be enough salvage to build a loafing shed or two.
   / Advise on Old Barn #6
Being that's all ice and sleet, that would be one heavy roof load. They do go down sometimes.
We've had big laminated wood beams spanning a school gym crack from snow and ice load, and they are supposed to be engineered for our conditions. Every winter when the conditions are right and folks don't get their roofs rakes or shoveled, a few go down around here too.
   / Advise on Old Barn #7
disconnect any power/hydro and pull well away, strip the metal, stack it on skids and chain saw it down to the ground. push into a pile and burn that old wood into a dust pile. biggest prob is all the nails that come from an old building as such. in your feet, tractor tires and seems to find there way everywhere after, nails that is. keep an eye out on craiglist or some site as such for metal detectors, start looking for nails. i hate nails and so do my tires.
   / Advise on Old Barn #8
They make magnets just for picking up nails. I had one that would pull them from 3" under ground if it was sandy.
   / Advise on Old Barn #10
Salvage that tin, you will be glad you did. It comes in handy for many projects and it you decide you don't need anymore, sell it, don't scrap it.
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
2006 John Deere HPX Gator 4x4 Utility Cart (A55787)
2006 John Deere...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
Loflin 48 Inch Pallet Forks - Global Carrier (A55218)
Loflin 48 Inch...
