1960-70's J. Deere Manhiem Germany Tractor Transmissions
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #1
cartod
Northern, West Virginia
JD 4066, 1023
I just bought my neighbors 1972 820 diesel German made deere and am having trouble understanding the reverse gears. A manual I got on line says it has 4 reverse gears but the tractor will only go into reverse in one gear. Some of the online searches show there to be only 1 reverse gear. Do any of you have any insight on what the deal is? were there 2 different types of transmissions?
That link is exactly my problem. You see it says 4 reverse gears on the spec sheet, But on the shifting diagram that is below the dash it shows that reverse is only attained in 3rd gear! My tractor will only go into reverse in 3rd gear.
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #4
cartod
Does your tractor have a parking brake? Does it have 7 or 8 forward speeds? 1st shift pattern is parts key #4. I sold 820 3 cyl tractors when then were new and all I remember selling had 8 speeds forward.
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #5
There were some oddities . Some of those 20 series Mannheims only had 7 gears ahead. Parking brake instead of a park lock . Open Center hydraulics when shopping for loader valves.
I don't have a link handy but there is a full parts book on the JD web site.
cartod
It does not have a parking brake but has a parking gear. However the decal on the dash shows no reverse gear for the right hand shifter. I am beginning to think that previous owner may have replaced the decal with the wrong one. It shows 8 forward gears and no reverse.
My tractor has the bottom decal on it, but it shifts like the decal in the center. and in the 820 factory manual it says it has 4 reverse gears.
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #8
The seven speed transmission was called a sliding gear transmission. The eight speed was a collar shift. The majority seem to have the eight speed. The only problem with the seven speed is availability of parts. It may be more appealing to a collector due to more rare, but parts are very rare to repair.
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #9
I thought the difference between the 7 and 8 speed was a block in the shifters that locked out 8th gear. All the gears are still in the the trans.
   / 1960-70's J. Deere Manhiem Germany Tractor Transmissions #10
To make matters worse there were 2 different model 820 built in Mannheim. One built for N American sales & one built for European sales. The N American sales model lists 2 different trans as jd110 stated.
TRANSMISSION DRIVE SHAFT ASSEMBLY
(COLLAR SHIFT TRANSMISSION)
TRANSMISSION INPUT SHAFT
(SLIDING GEAR TRANSMISSION)
Same thing with European built
12 - CLUTCH SHAFTS WITH SLIDING GEAR TRANSMISSION
13 - CLUTCH SHAFTS WITH COLLAR SHIFT TRANSMISSION
14 - TRANSMISSION CASE WITH SLIDING GEAR TRANSMISSION
16 - TRANSMISSION CASE (COLLAR-SHIFT TRANSMISSION)
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
