Toilet Paper
   / Toilet Paper #61
Can't go wrong with Charmin ... life is too short to use cheap-o TP
   / Toilet Paper #62
I put one on a nail in the shops bathroom to see who knows what it is for. You know there has only been 2 people that knew out of maybe 50 people. It's been there for 11 years.
Leejohn
Remember there were red cobs and white cobs. and not recycled only dropped in the hole. The white was to double check if
needed another red.
ken
   / Toilet Paper #63
Tell you one thing for absolute sure, the size of them sheets has shrunk a **** of a lot faster than my hairline. Got to the point now that there's almost inch and a half of empty space on the spool holds the paper on the wall, and that roll filled that space 10 years back.
Not to mention that they seem to have fluffed it up or wound it looser on the roll too. A roll doesn't seem to last as long as it used to.
   / Toilet Paper #64
Might not be a problem with the roll but with the end user so to speak :D .
   / Toilet Paper #65
A bit of irony here: As I was reading this thread last evening I heard the water alarm go off in the basement. Seems that the main line from the basement to the alley was plugged and backing up in the furnace room. Called the plumber this morning and we run 90' of "roto-rooter" out to the alley. Problem fixed. First time we've had to do that in this house and we've been here near 40 years. Never did figure out what caused the clog but I suspect grease buildup over the years.
S**t happens.
   / Toilet Paper #66
This thread reminds me if those toilet paper dispensers that make it hard to pull the TP out. Seems like you get one square at a time and it is ripped down the middle.
2002 TOYOTA 7FDKU40 FORKLIFT (A54607)
2002 TOYOTA...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
