Is Yanmar going to change colors
   / Is Yanmar going to change colors #11
I really like the looks of the new yanmars. I can't wait to see them bring out some bigger tractors too.
   / Is Yanmar going to change colors #12
Is that loader made out of oval steel?
   / Is Yanmar going to change colors #13
Looks that way Tom, Kind of sleek.
   / Is Yanmar going to change colors #16
Just curious, does the tubular shape offer an advantage from an engineering standpoint?
Steve
   / Is Yanmar going to change colors #17
Steve
Actually I think the opposite. The strength comes comes from the amount of steel as distant as possible from the center. That is why there are flat top and bottom edges on I beams, not curved inward.
   / Is Yanmar going to change colors #18
This is true, but sharp angles will concentrate stresses in those locations, which is a benefit of curved forms. I'm not enough of a mechanical engineer to know how the rectangular vs. oval tradeoff would work out in this instance, but I think it's more complex than simply one shape is automatically better than the other.
   / Is Yanmar going to change colors #19
Would the curved forms would be more costly to fabricate?
Steve
   / Is Yanmar going to change colors #20
Steve
Yanmar builds big excavation equipment, huge diesels for container ships, and a broad variety of specialty planting/harvest equipment so I expect they have the fabrication equipment already. More important they have a design philosophy to simply build the best regardless of greater fabrication cost, and the customers they want will pay what it takes to own the best. (Yanmar quality and value are illustrated by the flood of 30+ year old, thousand-hour gray market Yanmars that arrived here in the past decade. These used 1980's tractors are far better value than a zero-hour Chinese tractor at similar under-10k price).
One thing I've noticed in photos of their Japan-market loaders on the older tractors, the bucket is farther forward than an American-design loader. I'm not sure why. I've read the principal use of these tractors in Japan is rice tilling and dairy use. Maybe a loader in dairy use is different from the earth/gravel loads a US loader is designed for?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
406 (A52706)
406 (A52706)
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
