Hobart feeder on a Lincoln?
   / Hobart feeder on a Lincoln? #1
Cpjlube
Champaign County, Ohio
Case ih 254
I have been doing some research and can't seem to figure this out.
I have a Lincoln Idealarc tig 300 300(single phase). Recently, I was given a Hobart Rc200 (three phase) with a 17 feeder on it. I don't have access to three phase.
I have considered building a single phase to three phase converter but I'm not sure what Hp motor to use to produce enough to run the Hobart.
Or is there a way to get the Hobart feeder to run on the Idealarc?
Thought maybe someone might know.
Chuck
I'm not sure. It's pretty old. How do I tell if it's cc or cv? Will it work at all if it's cc only?
Can I run the hobart on a rotary converter?
   / Hobart feeder on a Lincoln? #4
It says right on the face plate variable voltage. Which equals constant current / CC.
I'll bet that feeder takes something like 24-volts to power it. And being as the Lincoln is CC only, you'll be pretty much stuck with running gasless flux core wire.
I've read where a phase converter to run a welding machine has to be huge!
Thanks for the help. Guess I just sell the hobart.
   / Hobart feeder on a Lincoln? #6
Sell the Hobart and buy a used LN-25, and get a K-126 gun for it. There is nothing wrong with gasless fluxcore wire. I've run a few pounds of it.
   / Hobart feeder on a Lincoln? #7
The Hobart feeder would fit on a Miller or Thermal Arc CC/CV power supply. Lincoln and ESAB have always been different.
   / Hobart feeder on a Lincoln? #8
You can run it on a Phase Converter if you have one. Not the best 3 ph out put but a lot of people do it. The feeder would be easy to sell and the power supply has a lot of Copper in it. Maybe more that the unit is worth. The Lincoln will not take a regular feeder. It's a monster tig stick unit. It could take a voltage sensing feeder like LN22 or 25, Hobart Hefty etc.
   / Hobart feeder on a Lincoln? #9
That's actually a fairly new Idealarc TIG 300 because it has a different case than the older TIG 300's. I'd guess from the late 80's to 90's. No, the Hobart 17 feeder won't work on it. The 17 was a very good feeder in it's day as were most Hobart machines. That machine looks about the same vintage. I'm not sure if the 17 feeder runs on 24 volts like a Miller or not. I think it might but needs to run off a CV (constant voltage) machine. Lincoln run on 42 volts I believe. I think you'd need a huge phase converter to run a welding machine. Maybe a welding supply would take the Hobart on trade or sell it on consignment? Then you get something like a Millermatic 212 or 252 and have good MIG machine.
Thanks for the advice. I might try a phase converter, just to see if it will run. I have a line on a 15hp three phase motor. I might try it.
Occasionally I run into three phase equipment that is cheap. I know a RPC would run a mill or a grinder. At least I could justify building one.
I'm also going to look into the suitcase mig units.
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
Diesel Fuel Tank And Pump (A51691)
Diesel Fuel Tank...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
