correct oil for 2000 new holland 1920 4wd
   / correct oil for 2000 new holland 1920 4wd #1
jhp123
Member
VA
1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
I have leaking fluid right at the left wheel where the rim appears to mount to the hub? What specific fluid is used and is a simple fix?
   / correct oil for 2000 new holland 1920 4wd #2
Do you know WHICH fluid is leaking?
   / correct oil for 2000 new holland 1920 4wd #3
New Holland 134 hydraulic oil, or any fluid meeting the MC134D specification. Your hub seal is leaking. Replacing the seal is not a difficult repair, and even if you have damaged axle bearings, a person with average mechanical ability and experience should be able to accomplish the repair.
Thanks for the help. I tried to upload a picture. If it doesn't load i will try to describe it. the fluid is leaking between the round hub that the rim mounts to, and the stationary part where it appears you can add fluid by removing a 13-15mm bolt?
We still talkin about the same item being worn Rick B? Hub Seal? Is it just an O ring or is it a special dealer item? Does that fluid also work for the rest of the hydraulics on this tractor? Thank again
   / correct oil for 2000 new holland 1920 4wd #5
Same spec oil is used throughout that tractor except in the crankcase & radiator. The seal is a dealer item, or so I suspect. Have your dealer print out the parts diagram for the final drive and the repair is pretty much self-explanatory.
ok great! Thanks for the help again. will post my positive repair results:) hopefully.
   / correct oil for 2000 new holland 1920 4wd #7
you can get an idea of the assy by going to the nh parts site and pulling up the exploded diagram ( has parts lists too.. )
Thank you Sound guy. Will do. Ordered part yesterday and should get it by Thurs or Friday. Thank You fellas.
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
