Anti Freeze Coolant - So What's The Story?
   / Anti Freeze Coolant - So What's The Story? #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
I'm going to want to change the anti-freeze coolant in my Kubota soon and so? I have no idea what's what with anti-freeze/coolant these days, what's right, what wrong. Any help appreciated. What would a typical AutoZone/Napa/O' Reilly type store stock that would be appropriate?
   / Anti Freeze Coolant - So What's The Story? #2
Over many years I depend on Prestone..set tractor -25F never had problem.
   / Anti Freeze Coolant - So What's The Story? #4
I have always used the standard 50/50 mix of prestone and water. If you buy it premixed you pay extra for that. Also some store name brands apparently according to a thread on here, are not what they claim.. I will stick to prestone in the yellow bottle and mix it myself.
James K0UA
   / Anti Freeze Coolant - So What's The Story? #5
I was told, only certain antifreeze should be used in diesels, and they are marked for diesel use?
OK, thanks for the replies. Question remains in my mind, is this diesel specific anti freeze available at your typical, neighborhood auto supply store? Will the label even mention use in a diesel?
   / Anti Freeze Coolant - So What's The Story? #8
im sure they are. but i got mine at tractor supply near me. after all i only needed 1 gal, was no big deal
   / Anti Freeze Coolant - So What's The Story? #9
The last time I bought some, it was very clearly marked for use in diesel over the road trucks, at Advance Auto Parts.
   / Anti Freeze Coolant - So What's The Story? #10
Well, "Hello, BP". Long time no see, but I've heard that you are still around. I just bought the Kubota branded coolant from the dealer. It costs almost twice as much, but flushing and changing the Kubota doesn't happen that often. Cheers, Hope you had a good garden season.
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
CAT 420D IT (A47477)
RIGGING BOX W/ MISC SHACKLES, LIFTING CHAINS (A54757)
RIGGING BOX W/...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
