1968 ford 3500 no pto
   / 1968 ford 3500 no pto #1
bksanti
Chino valley az
1968 ford 3500
Hi I'm new this forum but I'll give it a shot. I have a 1968 ford 3500 industrial tractor. Has a 3 point hitch but no pto. How would I run a mower or other attachment. Could I add a pto? Thanks Ben.
   / 1968 ford 3500 no pto #2
Not practical to add a PTO, you'd have to change out from transmission Back. You could add Hydraulic drive motors but that can get costly.
We're would I tie the hyd controls into.
Can I put a out put shaft in the spot in the rear of the tractor.
Thanks Ben
   / 1968 ford 3500 no pto #4
Thanks Ben
That's a pretty old tractor and parts may not be readily available...and if a PTO wasn't an option when the machine was new...well, adding a PTO drive is not feasible. Nothing is impossible, but I'm sure it would cost more then the tractor is worth.
   / 1968 ford 3500 no pto #5
I bought an entire rear end (PTO, 3 point, brake to brake) for converting mine.. Paid $600.
Thank you. I think ill use a hyd motor with controls. Just don't know where to tied them into the tractor hyd system. Thanks Ben
   / 1968 ford 3500 no pto #9
You would supply the pto valve first from the loader pump. Then, PB from the pto valve to the loader valve. IIRC, the pump should be somewhere around 17gpm for the loader. You could probably get everything you need from surplus center.
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
New/Unused AGT Industrial LRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2017 JOHN DEERE Z950M LOT NUMBER 86 (A53084)
2017 JOHN DEERE...
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
