Anti Freeze Coolant - So What's The Story?
   / Anti Freeze Coolant - So What's The Story? #21
I would follow the Kubota Operator's and Maintenance guide to the letter and DO NOT use ANYTHING marketed as "universal". The coolant suppliers cannot test their formulations on every conceivable product combination, but the OEMs can and do. I'm not saying you need stuff from an orange bottle, but whatever you do use must be prescribed by the book.
Many antifreeze formulations react negatively with some, or many, of the older fluids so caution is the word of the day. BTW, if you mix antifreeze types and have a negative reaction, you will be the only one spending time, effort and money fixing it. The supplier will not care or participate, regardless of what it says on the bottle.
PS: Be sure to use distilled water for make-up, tap and well water can have minerals that will reduce the fluid's useful life.
   / Anti Freeze Coolant - So What's The Story? #22
Whoever decided to make a coolant that was not compatible with other coolants was nuts. Could you image that with engine oil?
   / Anti Freeze Coolant - So What's The Story? #23
Oh they have! Detergent vs non-detergent, API S vs C (spark vs compression ignition) and CI-4 vs CJ-4 (cannot use CI-4 on newer diesels with DPFs.
It is a HUGE problem for the consumer, fluid companies say their products are compatible, but the reality is much different.
   / Anti Freeze Coolant - So What's The Story? #24
   / Anti Freeze Coolant - So What's The Story? #25
Maybe someone on the forum could do a pictorial antifreeze change on their BX for us visually oriented owners. I always need pictures when it comes to building or repairing things. Too much TV when I was growing up, I guess. That thread of the 50 hour service was excellent. I refer to it all the time.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
