Max 28XL HST and Post Hole DIgger question
   / Max 28XL HST and Post Hole DIgger question #1
chvfrk98
Black Jack, MO
Mahindra Max 28XL
Looking at ETA compact line of post hole digger. I just want to make sure with the smaller size of this tractor that I will still be able to dig a nearly 4' deep hole? I'm just worried about the lower arm vs other models I was looking at.
Any experience with this here?
   / Max 28XL HST and Post Hole DIgger question #2
Is this the link you are looking at: ETA Brand Post Hole Digger for compact tractors. Made in USA Free Shipping to your home within 1,000 Miles!!
I have only anecdotal stories about post hole diggers so consider everything I say as a load of manure.
First: The season that you are using it and your location makes a large difference. If I was in west Texas in high summer drilling into caliche -- a post hole digger may work. But I would see about a jackhammer instead.
Second: Sometimes you may be better off getting a four inch drill bit and a one inch. If the soil is a bear with a lot of loose rock, you may be better off drilling a bunch of one inch holes and then use a four inch to make the central hole.
Third: Do you really need a post hole? And is the hole too large? If you put a 4x4 post in cement, even treated wood, it will rot. So if you put the 4x4 may break off in two years if it the drainage sucks, and it is constantly wet.
Like I said everything I say comes with an anecdotal a load of manure, but think about it.
This immediate project is a standard privacy fence replacement. It's been over 20 yeArs and everything is shot. I have seen some with galvanized posts but I will probably stick with standard treated lumber. Soil is a clay but clean. Problem is I really want to get to 4ft deep. I also want to do pilings for decks and a shed.
My concern is the geometry of these is it allows you to go that deep? And is it on a single or multiple passes with an extension.
   / Max 28XL HST and Post Hole DIgger question #4
I used a 4 footer to put a post in for a gate. Made from a cut tel pole. Had to take my quick hitch off and set the arms up high and dig down about 8 inches to get the auger on. Other than that it worked great on my max 22
What post hole digger do you have? This compact one looks like it has a little more adjustment for compact spacing. I'm guessing I'll be fine. As long as there's a way to make it work I'll be good
   / Max 28XL HST and Post Hole DIgger question #6
. I rented it, no clue what brand.
   / Max 28XL HST and Post Hole DIgger question #7
Do you have to go down four feet for a fence?
I want to get past the frontline to meet code here is 3' but I also have some pilings in the future that I would prefer to take 4'. Also the gate post I'd like to take down deeper.
   / Max 28XL HST and Post Hole DIgger question #9
Given the extra height of the 28vs22 I would expect you to have no problem. I rented one for 50 bucks for a half day. A new one is about 400 I think.
That's was frost line and I'm thinking your right. Thanks for the info
2022 Kubota SVL75-2 (A50120)
2022 Kubota...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2000 International 4800 (A50120)
2000 International...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
2021 International HV507 4-Door 4x4 12ft Dump Truck (A51692)
2021 International...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
