Brianksnyder
I have a 1994 JD 770 compact tractor, with a Yanmar 4cylinder diesel engine. Over the years the mice have eaten portions of the ignition wiring harness, so I resorted to wiring a simple push button from the two wires on the starter. That has worked well until now. When I turn on the key the fuel solenoid does not engage, and initially I suspected a problem with the seat safety switch, so I warped a zip tie strap around the switch to make the contact, but still no go. I suspect there is more damaged wiring and would like to know if its possible to hot wire the fuel solenoid to a simple on / switch. There are three wires leading the the solenoid, one red and two yellow. Does anyone know if this idea will work, and which wires need to be switched?
