SCUT with cab for front mounted snowblowing
   / SCUT with cab for front mounted snowblowing #1
Avondale
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Can anyone offer ideas for a SCUT that has a factory cab, (defog, wiper, etc) and a front mounted snow blower option. Perhaps in 25 to 30 HP range? Not really interested in a lawn tractor w/blower and an after market plastic type windshields. Make and model, please. Thanks for your help. Merry Christmas
   / SCUT with cab for front mounted snowblowing #2
I thought I remember a posting here about TYM offering a front snow blower and a cab. I googled it and found a 2013 listing from a dealer in NY for such a set up available in 23-35 hp. I also saw a Mahindra listing also on Google. I know some of the guys here have those, check the post "pictures of your snow weapons".
   / SCUT with cab for front mounted snowblowing #3
Do you want to mow as well? IIRC, the Kubota B3000 is the smallest CUT with a factory cab. We have a Curtis cab with a heater, wiper, etc on our BX2660 and it works well.
Kubota also has the F series front mount mowers which can be had with a cab and a snowblower, but they are significantly more expensive than a BX or B...
Aaron Z
Ok, Thank You for input.
   / SCUT with cab for front mounted snowblowing #5
I also have the BX2660 with a curtis cab and blower. I am very satisfied.
   / SCUT with cab for front mounted snowblowing #6
I don't think there is a SCUT from any of the manufacturers with a factory cab. You'd have to install an aftermarket cab if you went with that size tractor.
The smallest CUT with a factory cab that I know is the Kubota B2650/B3350.
Thank you all for suggestions. Do the Curtis cabs have any problems fogging up/visibility in snow clearing? Can they be removed for summer use?
   / SCUT with cab for front mounted snowblowing #8
Having had an aftermarket cab on my previous tractor, I'd say yes.
Even my factory cab on my L4760 fogs when I first get in it. I need to run the heat on high for a while before it starts to clear up.
   / SCUT with cab for front mounted snowblowing #9
I have a factory cab tractor. Not a scut. But I do get some fogging up as well. Once you get good heat going and airflow most of it will dissipate. Curtis has always made a good aftermarket cab. I would prefer a curtis cab for winter and than i can take it off for summer use. But i got a deal on my tractor that i couldn't pass up. Also note,once my tractor cab is blowing heat, I turn the A/C on slightly to help with the DE-humidication process.
   / SCUT with cab for front mounted snowblowing #10
Having had an aftermarket cab on my previous tractor, I'd say yes. Even my factory cab on my L4760 fogs when I first get in it. I need to run the heat on high for a while before it starts to clear up.
Eric,
If you run the A/C it will clear up the fogging as it will remove humidity.
In my truck I run the defroster/heat on high with A/C on and it clears right up.
Don't know if it's an option on your tractor
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2013 John Deere 824K Wheel Loader (A55302)
2013 John Deere...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55302)
PENDING SELLER...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
SHOP SNAP ON TOOLBOX (A55745)
SHOP SNAP ON...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
