Back Blade worth buying??
   / Back Blade worth buying?? #1
jodebg
New Hartford, CT
Kubota B-2650
I am new to tractors and need to make a dirt road.
Just saw an older 5 ft back blade for sale.
Wondering if it would be worth buying? What does a back blade do
that I would not be able to do with the 60" front bucket?
It looks as if it is a few years old-paint coming off and hardware
is rusting. Was stored outdoors.
Asking price is $150.
Worth having and is the price fair?
Thanks!
   / Back Blade worth buying?? #2
For ditching you want heavy duty.
When blade set at 45 degrees will blade cover your rear tires?
Does blade have adjustable level wheels or can be install?
Will scraper blade be use for snow removal?
   / Back Blade worth buying?? #3
You can do a lot of things with your front bucket. You can do a lot of things with 3pt implements. Each thing has it's intended purpose and works waaaaaaaaaaaaaaaaaaaay faster and better than the other for those intended purposes. I believe that you would be better off using the rear blade for your dirt road. Now chances are that the blade for sale is not really heavy enough to do a good job (375-500lbs) but the combination of a light duty blade and your loader would be better than just the bucket in my opinion. If you are lucky and the blade is heavy enough, I doubt that you would even use the loader at all for any of your grading purposes.
Yes, about any usable implement is worth $150.
Just my :2cents:, good luck with your decision. ;)
   / Back Blade worth buying?? #4
If your tractor can handle a bigger one, I would pass on the 5'. If 5' is what size you think you need then offer him $125, I bet he takes it.
   / Back Blade worth buying?? #5
Make sure you can spin the blade backwards. If you can't, don't buy it.
   / Back Blade worth buying?? #6
Unsure what work you need to do to make your dirt road (remove sod, brush etc?). If so then the back blade is not the right tool. I've used mine for everything from grading to snow removal to steadying loads when lifting logs onto the sawmill. A very useful implement without question but it does have it's limitations, removing top cover isn't something it will do terribly well. For that you may want to look at a box blade.
For $150, if it's in relatively decent shape and will fit your tractor I would recommend buying it, certainly an implement you want to have.
No, the blade and the rear tires are the same width.
I need to fill in some low spots and raise the ground level a bit with some stable material to drive on.
Also, a stretch of land has some nasty, large and dense pricker bushes that I need to clear before entering the area.
What's the best way to clear them without a hack hoe the reach in pull them by the roots?
   / Back Blade worth buying?? #8
Everything is a decision to bE made upon your circumstances. I have a 5 foot blade on my JD855. It is wider than the wheels and tilts to make 'gutters' for my gravel driveway. For that, it's pretty good, For leveling, not so good--a box blade is better. Wish i had one, but I don't need one.
On my property, we have a lot of rock just below the surface but when one surfaces, the back blade will usually pop it right out. I have tried and failed to push over some trees with the blade. It will pull out some small stumps though, going forward. It pushes gravel pretty well but leveling is a PITA.
I agree that being able to swivel 360 degrees is essential.
Decisions, Decisions!!
Good luck!!
   / Back Blade worth buying?? #10
Please tell me why this is important. Thanks
Sometimes you want to blade with it backwards. An example is plowing snow on a gravel drive before the frost sets in so that you don't pick up gravel and dump it in the lawn.
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A51222)
2017 CENTAURO...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
2016 ROADTEC RP-190E ASPHALT PAVER (A51222)
2016 ROADTEC...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
1261 (A50490)
1261 (A50490)
