SCUT with cab for front mounted snowblowing
   / SCUT with cab for front mounted snowblowing #11
Eric,
If you run the A/C it will clear up the fogging as it will remove humidity.
In my truck I run the defroster/heat on high with A/C on and it clears right up.
Don't know if it's an option on your tractor
The problem with the L4760 is the size of the cab. When I first get in, I usually end up with a light coat of ice on the windows and even with both the AC and heat on it still takes some time to clear it up. The rear windows usually clear first since they have the heating element built in.
If I kept it indoors, I'm sure this would be less of a problem. However, it looks like I won't be able to get my building installed until spring now.
   / SCUT with cab for front mounted snowblowing #12
"Can anyone offer ideas for a SCUT that has a factory cab, (defog, wiper, etc) and a front mounted snow blower option. Perhaps in 25 to 30 HP range?"
How about the B3000.
   / SCUT with cab for front mounted snowblowing #13
Thank you all for suggestions. Do the Curtis cabs have any problems fogging up/visibility in snow clearing? Can they be removed for summer use?
They can theoretically be removed, but it would be ~2 hours worth of work (especially with the heater). We pull the windshield, doors and back off of ours for the summer and mow that way.
As for fogging, ours does some, but not so much that it blocks your view. Its warm enough (once the engine is up to temperature) to plow in shirtsleeves when its in the teens and blowing like crazy.
Aaron Z
RFB: Good looking outfit, thank you for sharing.
   / SCUT with cab for front mounted snowblowing #16
Thank you, it works well.
It is Kubota OEM blower on the OEM quick hitch, it uses the FEL joystick to control raisie and lower and spout rotation. It is spec'ed at 63"
The rear glass has the defrost wiring, and the A/C operating in conjunction with the heat prevents/removes any interior fogging.
It is quite powerful; more than I would have thought.
   / SCUT with cab for front mounted snowblowing #17
Kioti does make a 25 or so HP tractor with an optional factory cab. I dont remember the model, but they had one with a front pto mounted snowblower on my local tractor lot last year. The cab is heated, but no a/c.
   / SCUT with cab for front mounted snowblowing #18
gtg,
I have zero issues with "The Other Orange", its where I started looking before I first went Kubota.
I do think that A/C in a dedicated cab is really important if not mandatory. Even in winter on a sunny day it can easily become a terrarium, and the defrosting/dehumidify function of the A/C during heating really eliminates the fogging condensation issues.
Thanks, I am not sure if that is in Canada, my dealer had previously mentioned a bigger model as start of line-up with factory cabs, (40, I think). I will check back with him when next in for my DK35 TLB filter. I may be asking too much from one tractor, perhaps a separate mower and cab'd tractor would be better for total needs/wants. Sadly, budget and BOSS will have an input into my plans.
   / SCUT with cab for front mounted snowblowing #20
And this year in West Central Idaho how would I know. I am about to wonder if I will need to mow the lawn (not really, just no snow to speak of).
Normally by this time of year I am mid-thigh heading to hip deep.
2012 Peterbilt 337 Mixing System Truck, VIN # 2NP2HN7X7CM159860 (A54865)
2012 Peterbilt 337...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
34015 (A53421)
34015 (A53421)
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
