Used Flail Mower.
   / Used Flail Mower. #1
Augusta/Martinez Georgia
2011 Kubota L3200 4X4 FEL
I am in the market for a Flail Mower and have located a used one near me. It is a Ford 917H. I am looking for some advice on what to look at, problems with that model, how much wear on the knifes/hammers is considered in need of replacement. Any help would be great.
Thanks.
   / Used Flail Mower. #3
I purchased one at a auction and it had always been shedded. My renters removed the tarp covering it in their never ending search for scrap metal to steal. The bearing on the left side with the belts on it filled up with water and froze. When greasing in the spring I helped but did not solve the ruined bearing. Keep the thing covered up and you will be pleased with the performance. Used it to mow lots in town . Really kept me from raking alot of leaves in the fall. Ford carries most parts and the belts are metric.
   / Used Flail Mower. #6
Rounding of the knives equates to narrowing of the individual cutting swath, so when to replace is dependent upon how finished you want the completed cut to look. If you're satisfied with less than a golf-course cut, a little rounding on corners of the cutting edge is acceptable. By design, there is individual cutting swath overlap that compensates in part for the missing metal. But at some point, individual knife wear progresses to the point where this overlap is compromised. That's the point at which the knives should be replaced. All this depends upon the original width of the knife and the degree of knife overlap. On the 917H I'm pretty sure the OE knife width (cutting swath) is around 2-5/8". When corner wear takes the swath below 2", I'd say it's time for new ones.
And when it becomes time to change the knives on a 917H, it's likely also time to change the hangers. The swinging knives wear grooves in their brackets. The deeper the grooves, the closer the knives swing toward the inside housing. When I bought mine, I replaced knives, hangers, hanger brackets, and the nuts/bolts/washers that held them in place.
//greg//
   / Used Flail Mower.
//greg//
Thanks greg for answering my question.
   / Used Flail Mower. #8
I owned a couple of these and love them. One got badly abused with the stones around here and the drum with its knife attachments plates was quite mangled but still serviceable. I sold that machine and kept another with the fine cut knives that I bought cheap at a municipal auction.
All in all, I love the fine cut better and the knives didn't disintegrate as I figured they would. Maybe the mass of the normal blades causes them to be destroyed when striking stones. At one point, I tried welding knives back together with obvious unsucessful results. One day I got an early christmas, when I found a pile of brand new knives at the dump! Maybe someone saw my welding attempts to save money and took pitty on me.
At one point I started removing all blades for sharpening and service but that became old, very quickly. In general though and in retrospect, that machine was a pleasure to work on. Years later, I found a specific electric sharpening machine at a municipal auction for those regular blades. I gave it along with my regular machine when I sold it to a friend.
Those machines arn't great for high grass (unless totally dried out) not good for wispy grass, and don't do much on very short grass, but anything in between works good. Watching the grass cascade out over the rear roller is like magic! Not sure why those machines have never been more popular. They don't use much HP either.
   / Used Flail Mower. #9
Just bought a 917 flail. Is the rear roller height adjustable? It resides at my property a couple of hours from home so I can't just go outside and look. Hope I'm not guilty of thread hijacking by asking the question here.
   / Used Flail Mower. #10
The issue with any high grass or heavy brush and a flail mower is the knive count. and power for the mule!!!!!!!!!!!!!!
Sadly for the mower buyer the death of the son of the founder of the Mott Mower Corporation
is what killed the greater use of these beautiful mowers.
They use flail mowers to a greater extent in Europe due to thier stricter mower safety standards.
Getting back to the construction issues of these things:
The Mott folks went to a smaller diameter flail mower rotor which
was a huge mistake simply because it created a need for longer
side slicers/grass knives.
These longer side slicer knives alway get tangled up with the
knives behind or in front of them and as result they are dinged quite often
This does not happen with a flail mower rotor that has a larger diameter as it requires
shorter knives.
The other item is rotor balancing where the smaller rotor "essentially a piece of bar stock"
was easier to obtain and use.
Larger diameter flail mower rotors are built with heavy metal tube steel and the
end discs are welded after the tube is eiter cut from a longer section or rolled
and welded together. then placed on a high speed balancer.
The small diameter tubes that are used have to be balanced when the weldments
are attached to them.
The problem with the current knives is simply one of cost as a tapered knive costs more
to make as it requires more grinding BUT the tapered knive also offers more
cutting edge to the job at hand and it also allows the knive sto last longer as they
are less prone to being damaged.
Sadly The folks at flailmaster are not at all interested with making tapered knives and
its shame because once people start using them they will see how well they cut and
they will sell many more knives.
If they offered the type of knive mounting stations/flail mower rotors
used on the mathews company lawn genies they would sell a lot of them
(they require no tools to change knives or add dethatching knives)
Sadly that is something you can not accomplish on the flail mowers sold today.
I have the same 32 year old motorised towed flailmower my father owned and I
would still have the first one he had if I had not offered it in trade for the wheel horse
I bought in 1990 and still own. need some work and a new seat but.......
Payment Terms (MUST READ) (A50775)
Payment Terms...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 Kubota RTV-X900 4x4 Diesel Utility Cart (A51691)
2016 Kubota...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
