Foaming Diesel Fuel
   / Foaming Diesel Fuel #1
Trails End
Gold Member
Candia, NH
Bobcat CT335
Yesterday, I stopped at the local Shell station to fill two 5 gal.
containers with diesel fuel. I filled the first container with no
problem but while filling the second container, the fuel was
foaming excessively, with resultant foam overflow. I had to
reduce the flow from the nozzle to a very slow rate in order
to finish filling the container without foam overflow.
Does anyone have any idea what may have caused the foaming?
I haven't poured this fuel into the tractor yet, since I'm not
sure if there's a problem with it. Has anyone else experienced
this while filling a container?
   / Foaming Diesel Fuel #2
Winter fuel in warmer temp or pump sucking air???
   / Foaming Diesel Fuel #3
It happens all the time when I'm filling cans at a service station, I just keep moving around three cans to let the air bubbles settle while I'm adding more to a different one. It only takes seconds for them to drop back. It's just the airation of the fluid as it splashes around.
   / Foaming Diesel Fuel #5
   / Foaming Diesel Fuel #6
I always assumed when that happened the tank was getting low. Could be wrong.
   / Foaming Diesel Fuel #7
The fuel in my area also foams a lot, it doesn't matter what gas station I get it from. I always assumed its normal. It also bio diesel in my area so I don't know if that makes it worse or not.
   / Foaming Diesel Fuel #8
We I was active duty, we always had to wait for the foam to settle before we could finish filling our jerry cans. Foamed a lot.
   / Foaming Diesel Fuel #9
Normal. Diesel is more viscous than gasoline; it traps air in fuel as it swirls into containers; foam forms.
Ralph
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
8ft Perforated Metal (A51573)
8ft Perforated...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
