Re-decking trailer
   / Re-decking trailer #51
um...? i use PAINT as the barrier...
Anyone placed some sort of barrier between the cross members and the PT lumber to isolate it from the wood? I'm thinking a strip of roofing paper or maybe neoprene or even some type of heavy duty tape.
If the wood were seperated from the channel in this way would it reduce/hinder corrosion of the frame where it contacts the wood?
   / Re-decking trailer #52
I wouldn't be surprised if the asphalt paint isn't just as bad, for the environment, as motor oil. They are closely related. The used oil thinned a bit with turpentine might make a good first coat. As long as you don't pour it on you could paint it on safely.
you'd be incorrect.
lookup the MSDS for asphalt pINT.
NOW CHECK OUT USED MOTOR OIL.
PS.. the bituminus asphalt emulsion product we put down as tack and prime coat for road work is environmentally inert once cured.
   / Re-decking trailer #53
you'd be incorrect.
Really? Totally inert - never breaks down? It is still asphalt with the same chemical make-up - basically the heavy ends of a barrel of oil which change somewhat from barrel to barrel. The motor oil will just break down quicker. Plus, once again, it is reuse versus a new product. Total amount of hydrocarbons in the environment is less with the oil just a little longer to release with asphalt.
I do agree with the comment about oil coating being much slicker when wet.
   / Re-decking trailer #54
you'd be incorrect.
   / Re-decking trailer #55
I live in Washington. Here used motor oil is considered a hazardous waste and there are laws regulating how it is handled. As long as it is not contaminated with something else that is considered hazardous asphalt is not hazardous.
   / Re-decking trailer #56
Used motor oil has all sorts of contaminates in it. That's why it gets removed from the engine.
   / Re-decking trailer #57
i didn't say totally inert. i said environmentally inert. IE.. what the epa considers inert .. check out the hazard info on the msds.
   / Re-decking trailer #58
I see some guys that are not thinking and believing the documentation the government puts out - the one size fits all. Three years ago we had an event where raw milk was a hazardous material and they had to have guys in jumpsuits to deal with a milk truck that had rolled over.
I am not saying that used motor oil is a good thing to have dripping around, and yes it has contaminates, that is one of the main reasons it is deemed hazardous - it is an unknown quantity to some extent. A government agency will not put its stamp of approval on it because it is not consistent. Whereas something like asphalt, even though it is made from the dregs of the oil barrel and has some inconsistencies, they are relatively known ranges of inconsistency and therefore it is deemed safe. This is a great example of how we have become a throw away society - we are not allowed to re-use anything which is the best recycling of all.
My wife the other day was telling me I should not re-use a water bottle as the plastic outgases and it gets into the water. Then a little while later she was complaining about her "non-stick" griddle that things were sticking to - so I asked her where the teflon went. She doesn't like it when I ask these questions. Another good example is that we are not supposed to use a milk jug to transport gasoline but we can use a special red plastic jug that is made out of the same polyethylene from the same plant to the same specs. Hmmmmmm!!!!
   / Re-decking trailer #59
Yum, yum, yum more lead, arsenic, zinc and cadmium for dessert please...
I have small kids, they WILL be on the trailer at some point. I have been around several trailers that had oil put on them many years before and they still had a nice sheen when they got wet (enough to make your finger slippery if you rubbed it on the boards). That means that it hadn't fully soaked in and was still coming out.
I would no more put used motor oil on a trailer than I would pour it on the ground.
Aaron Z
   / Re-decking trailer #60
Aaron Z
yup.. it won't cure and will leach.... might as well just pour it in the cities well.
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
24631 (A55853)
24631 (A55853)
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
SARLO MOWER (A55758)
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
