frame nuts?
   / frame nuts? #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
Okay... so this isn't a tractor question but... I am changing the steering box on my sister's '04 grand cherokee and to get to the mounting bolts I need to remove the washer fluid tank, but to do that I need the get the sway bar out of the way. I thought I would just remove the mounting bolt for the bushing brackets, but that's where the problem is.
I got three out and the fourth came out about three turns then got stuck. I was using an impact and it broke loose the "nut" that seems like it was welded inside the frame. So now the bolt is loose and spins freely. I can't tighten or loosen it. The frame is boxed so I can't do much. Any suggestions?
Also, does anyone know if the front of the frame tubes are open? If I pull the bumper off, I can probably reach it. Then I could just cut the bolt and put a real nut on the inside of the frame. I may just weld the bracket on if I have to.
   / frame nuts? #2
Can you reach the back side and cut a hole in the frame with a hole saw large enough to get a socket in there?
   / frame nuts? #3
Zip the head off with a cut off wheel, then use a threaded insert for the replacement.
   / frame nuts? #4
One option: Remove bumper and LS EA unit. Confirm access to the offending nut thru the front frame horn. Grind off the bolt head and remove the box. Poke the bolt/nut into the frame and remove with a magnet. (Grind the bolt shorter first if longer than the frame is wide.)
Solder or weld a med-stiff wire to a replacement nut so that it can be reached in & held in position to start on a new bolt. (have done this elsewhere up to 30" or so 'deep' when installing hitches) Be sure that you pre-check the nut to spin freely on the bolt beforehand so it's easier to hold from turning when drawing up/tightening the new bolt. A nick in the wire close to the weld/solder/braze may allow the wire to snap off close if the nut turns just enough before it bites in when tightening. (Girls don't like rattles)
There are sometimes openings in a frame that would allow access near to and nearly opposite the busted nut's position, but I doubt you'd see them on the GC's frame anywhere near there. Could be an alternate way in vs thru the front end of the frame, but I wouldn't count on you being that lucky.
   / frame nuts?
No, I can't really get to any part of it.
This is what I figured I will have to do, just don't want to go through pulling the bumper off because of all of the plastic crap, and then find out that the frame isn't open in the front. I am also not sure what airbag sensors I will find, or how to handle them... will the airbags deploy with the car off? I guess it would be best to disconnect the battery just in case. Btw- the bolt that I am having the issue with is the sway bar bushing bracket, not the actual gearbox. It is the one on the passenger side and is only probably about 8 inches from the front of the frame so if it is open I can probably reach it with a wrench. The bolt come up from the bottom through a nut (or some sort of threaded insert) on the inside of the frame.
I looked for other access point but can't really find anything, just a few holes on the sides of the frame about 3/4" round. I will look one more time before I start to pull off the bumper.
Thanks for the responses guys.
   / frame nuts? #6
I'd check with a body shop that deals with these on a regular basis- they might be able to suggest a way And be careful of the air bag sensors; find out how they're triggered and if bumper removal could deploy them.
   / frame nuts? #7
I've yet to see a manual that didn't advise de-activating the SIRs by just removing the fuse, say when working on the s-wheel or column, and not resetting radio/clock/security by disconnecting the battery (still a safe bet, tho) That's all it should take. "Got manual?" (Chilton, Haynes..)
   / frame nuts?
No, it's not my car and I didn't think I would need one for a steering box. I really don't waste my money on haynes manuals anymore anyway, chiltons seem a little better but since I mainly only work on my own vehicles (and sometimes close friends/relatives) and I keep vehicles forever I usually invest in factory service manuals. Actually it was pretty easy going until this happened.
So for now I will call it somewhat of a success. I pulled the bumper facia off this morning and I was able to get right into the frame tube without even pulling the bumper. The nut was luckily a hex and I was able to reach it with a wrench, so that and a 24" breaker bar and I was able to get it off... didn't even have to cut it. I was leary using a cutoff wheel because I would have had to have it about 1/2" from the plastic radiator tank- one small slip and this job would have gotten even worse. Now to replace those stupid plastic clips from the facia... I broke about half of them, but they don't look like they were intended to be reusable anyway.
Thanks again for the help everyone.
   / frame nuts? #9
I beleive you will find it is a 1 inch square nut that is held in place by a square 'keeper' that is welded to the frame. That is what keeps the body on the frame of older cars. I found this when replacing the floor panels in a '65 chevelle. I had to cut the bolts to remove the body then cut the 'keepers'. then I made the nut ( no one stocks these) and then weld the keeper back in place over the nut.
   / frame nuts? #10
... I really don't waste my money on haynes manuals anymore anyway, chiltons seem a little better but since I mainly only work on my own vehicles (and sometimes close friends/relatives) and I keep vehicles forever I usually invest in factory service manuals. Actually it was pretty easy going until this happened....
I always preferred Chilton to Haynes for the easier indexing and better illustrations, many more pages, excerpts from OEMs ... until Haynes took over and merged the brands. Pics are a lot better than the older Haynes and some of the illustrations/extras remind of the more user friendly Chiltons of old. Perhaps as often as I've taken on a new job (charitable, if you will) the 'customer' would pay for parts & a manual that I could keep for doing the work (and/or to 'revisit' the vehicle/model). I had to build a bookshelf to pile them onto, and if there's a brand of book I always favored for depth and ease of use it was Clymer (motorbikes).
Good news is that the OP got 'er done without major hassle. :thumbsup:
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
