Help finding replacemnt Lift Pin for Gannon Box Blade
   / Help finding replacemnt Lift Pin for Gannon Box Blade #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
Picked up a used Gannon 78HB with hydraulic scarfers. :thumbsup:
Need to find a replacement Cat 2 Lower link pin and can't seem to find any. Need Cat 2 without threads, just a pin.
Anyone seen them around?
Next need to add rear remotes and TnT... Let the fun begin......
TIA!
J
   / Help finding replacemnt Lift Pin for Gannon Box Blade #2
I would say to contact Woods and get what you need for the model # that you have.
Have you checked on the cost of the rear remotes for your tractor? When you do, think about getting 2 of the 3 with the float function. Should be a little over $2000.
As far as the box blade, float can sure come in handy with the side link and for the top link it can be useful when mowing, along with other uses.
As far as top & tilt sets, the Kubota "T&T" set is $871 or an after market set runs $740.
You sure found yourself a great implement there. :cool:
Let us know how everything else goes. :thumbsup:
   / Help finding replacemnt Lift Pin for Gannon Box Blade #3
Tisco P7236 through some dealers or online at Glemco online or A&I Products A-LP21, same as P7236 or A-LP20 9" useable length. All Cat 2 pins for this purpose.
Top/Tilt kits through Tisco are good. What make/model? Also, Gearmore in Pomona, CA makes several T/T kits that are very complete.
   / Help finding replacemnt Lift Pin for Gannon Box Blade #4
TIA!
J
The simple way to do it is just buy a straight 1 1/8" hitch pin such as any tractor supply or dealer will carry. just pin the two outside clevis plates together which requires just over 4" length plus room for a clip. Tractor Supply stocks them in a longer length which will work fine too.
For the tnt setup I would recommend Brian with Fit Rite Hydraulics, good service and prices too.
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
