Bad sheetrock prep for paint
   / Bad sheetrock prep for paint #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
Any expert sheetrock finishers/painters on here? I've got a project that has stalled because I'm not sure what's the best way to proceed and could use some expert advice.
Missus decided to strip the wallpaper in the little bathroom and paint it. I don't know how the walls were originally prepped for the wallpaper, but evidently it was poorly. It looks like the wall was sheetrocked, mudded, then primed with a coat of latex and then papered. Probably not sized. The paper was extremely "stuck". Paper tiger was required, plus multiple applications of DIF. Even so some sheetrock paper was damaged and parts of the latex prime coat peeled, leaving lifted edges.
I have used a water soluble white-glue-like product before to prep damaged sheetrock paper, so maybe that will help with that, but I really don't know what will work to address the peeling edges of the latex. If I try to sand off the remaining latex, I'm sure that MUCH more paper damage will result.
The desired end-point is a smooth enough surface so that it can be final finished with regular latex paint.
- Jay
   / Bad sheetrock prep for paint #2
I am not an expert but have hung hundreds of sheets of drywall and taped and mudded many of them. You don't say how large the room is or mention what fixtures there are or how many electrical outlets are in place. Is the ceiling drywall or suspended? First floor, or basement? I recently redid a 1950 vintage bathroom that had terribly poor walls and ceilings, they were in such poor shape I removed the vanity and stool and drywalled over the existing walls and ceiling using 3/8" drywall and box extenders for the electrical outlets. Most bathrooms are small enough that very few joints need to be taped and mudded. The reason I asked if the bathroom you have is on the first floor or in the basement is that no matter how hard you try to repair existing drywall and paint, any moisure will cause more issues down the road. A second alternative is to install decorative paneling over the existing walls. Not sure if these suggestions help, though.
   / Bad sheetrock prep for paint #3
Or, just demo and re-do, with backer board if moisture is a real issue.
   / Bad sheetrock prep for paint #4
Stick895, problem with demolition and redo is that some older homes have REALLY thick walls...the bath I recently redid had 3/8" drywall covered with a layer of plaster, with ANOTHER skim coat of plaster atop that layer. The horizontal ceiling to wall corners had reinforced WIRE MESH so the plaster would have something to stick to and whoever installed the mesh wanted to use as many nails as possible to install it. It was so much easier to just add another layer of drywall.
   / Bad sheetrock prep for paint #5
Been there done that. Existing bathrooms are hard to replace drywall so I would scrape as much as possible and then skimcoat as needed. I like using setting type compound that you mix because it seems to set harder in thin layers. I also use a screen sander with the shop vac to minimize the mess.
   / Bad sheetrock prep for paint #6
That wall looks pretty rough. not ready for paint. I'd would get the new remodel drywall thats 3/8 and screw on walls. If worse comes to worse, you can always tear down old and put new stuff that is mold and moisture resistant for the bathroom.
   / Bad sheetrock prep for paint #7
I did a bathroom long ago that had the ol' sheetrock and 2-coat plaster with wire mesh in the corners. I didn't want to do the ceiling, just the four walls.
The outside wall had blown cellulose insulation, and seeing that I wasn't knocking it out of place and to avoid re-stuffing it I hastily threw up some 6 mil plastic, stapling it thru' cut-up squares of cereal box. 6 mos later and tired of taking baths vs showers (oh, I do procrastinate) I green-walled over the intact plastic and called it a 'vapor barrier'.
But, what about the mesh around the ceiling's perimeter?? A curved-ended chisel in an 'burp gun' (pneumatic chipping hammer, ~$15 for the set at HFT) went thru' it like butter just walking it along, and not adding much dust to what busting all that plaster had generated anyway. (!) With mesh still in place beneath where plaster had crumbled an inch or so out from the very corners I had no trouble taping & mudding as usual. (thin coats there, allow for shrinkage) btw: when I finished that one the GF move in. :dance1:
A pal didn't wipe down the dust too well from a recent bath redo and primer bubbled where it didn't stick. Wifey wanted her colors, not work to do, so they topped over that without fixing the spots first. I was reminded that even the best sealers (KillZ orig for me) can't guarantee to stop old s__ from working it's way to the surface elsewhere, a case for tearing some down and re-sheeting where you logistically can.
   / Bad sheetrock prep for paint #8
How did you get pictures of my house?
Looks exactly like my ongoing projects.
Former owners used shelf type paper for wallpaper. It ALWAYS takes off chunks up to the 1/4" deep when removed.
Where I had a large section with few corners to trim I demo'ed and replaced. In tight areas I sanded down and put on skim coats with the widest knife I could find (18"?) and sanded smooth. It isn't fun, but slow work is best. I find it easier to put on a lot of skim coats and sand it down.
Thanks guys. I shoulda noted that this is a small 1/2 bath, so no real water issues and no mold. First floor, only three electrical boxes (light, light switch, outlet), one HVAC register. About 1985 construction; 1/2" rock for walls and ceiling. As far as I can tell, there is nothing in the wall/ceiling joints except a tape/mud joint.
I hate to demo and redo or cover over with 3/8 because I want to TRY to avoid removing the vanity and a large glued-down mirror above it. Also hate to remove the base mould and shoe mould, but that's not as much of a consideration.
For skimming over, would regular mud (joint compound) work best or a modified thinset? KennyG, exactly what do you mean by "setting type compound"?
- Jay
   / Bad sheetrock prep for paint #10
When you buy drywall compound you can buy the bucket/tub of premixed stuff or you can buy "setting type" which is dry powder in a bag. The setting type comes in various types that set in 20, 45 or 90 minutes. I suggest getting the "lightweight" or "sandable" versions. Maybe it's just me, but I find it easier to work and stronger than the premixed stuff.
(7) SHANK CHISEL PLOW (A54756)
(7) SHANK CHISEL...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2006 Pierce Quantum Hale Pumper Fire Truck (A55788)
2006 Pierce...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
